yarnos wrote in post #2770139
I just come back from shooting a new Restaurant that launched tonight
I noticed that the Archietect had gone into great length lighting up the the bottles.. I attempted in taking this image but i never seemed i could get it right! the white light in the background was showing overexposed in the Histogram..... How would you setup up the Flash to ensure that the image is well exposed? How can this image also be taken creatively? any ideas out there!!!
Its hard to tell just looking at one photo (and its on my bad work PC monitor), but I would let that bright white back ground over expose. Its ment to be white, and I would assume its ment to be bright clean white, and letting it over expose will give you that.
So, manual exposure, on a tripod, and expose for the rest of the bar.
If your luckey you will get one good exposure of the bar and bottles on the shelf with a bright white background.
If your unlucky the bright white behind the bottles will be so much it will also over expose some of the bottles as well, in which case you might find it easiest to take to two exposures, and combine them.
With regard to useing the flash to light it, I would use two, one to each side of the camera.
If you use E-TTL then you will need to adjust the FEC to allow for the bright white behind the bottles, otherwise shoot with manual flash as well.
Still aim to slightly over expose that bright light behind the bottles, thats a lot of shiney surfaces for flash to reflect off
