The more i use my camera the more i stay in munual, maybe my crama is just a fruit but AV mode leads to soft images, and often under exposed and TV also seems to lead to under ex. images.
Thus i'm always in manual, just wondering if i'm normal.
| POLL: "Which one do you use most?" |
AV | 50 42% |
TV | 17 14.3% |
M | 21 17.6% |
P | 27 22.7% |
Full auto | 2 1.7% |
bounce between automatic modes | 2 1.7% |
timmyquest Goldmember 4,172 posts Joined Dec 2003 Location: Outside of Chicago More info | Mar 24, 2004 12:47 | #1 Permanent banThe more i use my camera the more i stay in munual, maybe my crama is just a fruit but AV mode leads to soft images, and often under exposed and TV also seems to lead to under ex. images. Capturing life a fraction of a second at a time
Cadwell Cream of the Crop 7,333 posts Likes: 2 Joined Jan 2004 Location: Hampshire, UK More info | Mar 24, 2004 12:49 | #2 I use one of AV/TV/P/M depending on what I am trying to achieve.... I guess I use TV most as I spend most of my time shooting motor racing and want to force a shutter speed in order to get that "almost frozen motion" effect leaving just a bit of blur to the wheels so that it doesn't look parked. Glenn
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Mar 24, 2004 12:55 | #3 I'll put "Av" since that's 70% of what I do, 25% Tv, 4% Manual, and 1% of the time I just hit the button without looking because I forgot to reset it from the last shot. You can take my 100-400 L away when you pry it from my cold, dead fingers.
Jesper Goldmember 2,742 posts Joined Oct 2003 Location: The Netherlands More info | Mar 24, 2004 13:03 | #4 Most of the time Av, because it gives me control over the depth-of-field. I often use it in combination with exposure compensation, either + or -, depending on the situation. Canon EOS 5D Mark III
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Mar 24, 2004 13:26 | #5 timmyquest wrote: The more i use my camera the more i stay in munual, maybe my crama is just a fruit but AV mode leads to soft images, and often under exposed and TV also seems to lead to under ex. images. When in manual does the meter tell you if you're under or over? Have you tried +1 EC when in Tv or Av? You can take my 100-400 L away when you pry it from my cold, dead fingers.
DarkEngine Hatchling 8 posts Joined Feb 2004 More info | Mar 24, 2004 13:52 | #6 I use M mode most of the time, sometimes use Av or Tv depends on the job, but strange thing is i never tried to use P, seems i can use M mode fast enough to respond to the whatever i want to capture ...
CyberDyneSystems Admin (type T-2000) More info | Mar 24, 2004 14:47 | #7 Timmy,. I edited the question to ask "which mode do you use The Most" so it was easier to answer. GEAR LIST
petiot Senior Member 283 posts Joined May 2002 Location: Montpellier - France More info | Mar 24, 2004 15:02 | #8 ohh, so some people do use P then ?? 10D and now 5D, 17-40, 24-105, 135 (whish list: 50F1.4, 1.4* converter)
MediaMagic Senior Member 573 posts Joined Aug 2003 More info | Mar 24, 2004 15:27 | #9 about 50% M, 30% AV, 20% TV/P/sports mode.
samdring Senior Member 392 posts Joined Aug 2003 Location: Crooked Spire, Derbyshire More info | Mar 24, 2004 15:38 | #10 CyberDyneSystems wrote: Timmy,. I edited the question to ask "which mode do you use The Most" so it was easier to answer. ![]() *************** I use "P" about 40% of the time,. I find that with both "wheels" I get the same control as I would get with TV or AV... with added simplicity when I'm rushed..) Now why did you not mention that before - never dreamt of wheeling in P mode. Have a Care
mson Senior Member 697 posts Likes: 1 Joined Mar 2004 Location: Colorado More info | Mar 24, 2004 17:20 | #11 I use M mode most of the time. It forces me to think about what I need to do and helps me learn the camera better. --Mike--
iwatkins Goldmember 1,510 posts Likes: 1 Joined Sep 2003 Location: Gloucestershire, UK More info | Mar 24, 2004 17:27 | #12 I gues AV the most (for landscape shots) but I'm always clicking that dial about in the "creative zone", all depends.
Pekka El General Moderator More info | Mar 24, 2004 18:25 | #13 M mode always. Only time I've used Tv mode is in rock concerts. The Forum Boss, El General Moderator
Lamplight Goldmember 1,072 posts Likes: 2 Joined Mar 2004 Location: Bellingham, WA More info | Mar 24, 2004 18:30 | #14 I'm still just trying to get a feel for my new camera right now, so I've been shooting a lot in "P". However, I've also been experimenting in all different modes and using different features.
CyberDyneSystems Admin (type T-2000) More info | Mar 24, 2004 18:45 | #15 Just an added note,. personally,. I find that AV, TV and P are almost the same thing.. since they are all universally adjustable.. GEAR LIST
| Latest registered member is semonsters 1480 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
