Thread started 25 Feb 2007 (Sunday) 11:49
New 5D
k9trainer
Joined Jun 2003
Feb 25, 2007 11:49 |  #1
I received my new 5D Friday and have been reading the manual so I can get as much out of the camera as it offers. With the 5D being my first DSLR there is allot to learn when it come to knowing how to use the settings on the camera. In the past I shot with a Hassy 500C and for 35mm a Nikon F2, so far the 5D just seems pretty much like any other 35mm film camera that I used in the past. I know it has allot to offer but I still wondering if shooting with the 20d or 30d is that much different form the 5D (since the 5D cost so much more). I plan on taking it out today to test it out some more.
The lens I received with the 5D is a Canon 28-135, what I noticed right away it the lens barrel seem clunky and loose, if you tilt the camera from one side to the other you can hear the lens clunk, I never seen a lens have so much play in the barrel especially when set closer to 28mm. Very cheaply made lens.
Canon 5D Mark IV & BG-E20
17-40L & 70-200 IS2.8 Mark II L
Canon1.4x ll & 2X II Extender
Canon 15mm Fisheye
Previously owned Canon 5DI, 5DII, BG-E6, Canon 70-2002.8IS L, 24-105IS L, Flash 580EX II
johneo
Joined Aug 2003
Feb 25, 2007 12:02 |  #2
Good luck with your new 5D!
Shooting with a 20D or 30D would probably not be a lot different but the results would be.
I assume you have the 28-135 IS? If so, yes it is clunky but I believe it has something to do with the IS. Not sure it's made cheap other than it's a lot of plastic but look at the cost of similar IS "L" lense and you'll see it as a bargain. I own a couple L lenses and I still like the 28-135 IS for much of what I shoot because for a non L lens it's well worth the price and gives great results.
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
JBF
Feb 25, 2007 12:43 |  #3
Yes, I concur. The 5D is a big step up from the 30D/20D. It has had an effect for me. Since the viewfinder is much brighter and bigger, I have had to learn to frame again. (Think about the shot). It leaves a lot at the sides and top and bottom which I needed to crop when I first go the camera. Don't be afraid to get in close and think about your framing. As far at the 28-135IS, I had this lens and it was fine on my 30D, but on the 5D is just doesn't have enough class. The 5D definetly needs "L" Glass if your going to get the most resolving power out of it. Or some of the nice and fast primes. 50 1.4, 85 1.8,
100 2.8, these lens look fantastic on the 5D. Have fun shooting, its an awesome camera, I just hope the next version has weather proofing and 5 FPS.
johneo wrote in post #2772071 (external link)
JBF
Canon 7D, Canon 1D Mark IV, Canon 24-105L f/4, Canon 35L 1.4, Canon 200L f/2.8, Canon 70-200L II IS f/2.8, Canon 300L f/2.8IS, 580ex Flash, 430ex Flash, 1.4X Converter. Bunch of other crap! I want the new 500mmL and the 200L f/2.0
Gidi ­ Morris
Feb 25, 2007 12:47 |  #4
I wish you a quick death!
Just don't forget to leave me the 5D in your will ;)
:p
flickr (external link) & deviantART (external link)
GMMorris.Com (external link)
Whats in my Domke?
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Feb 25, 2007 23:32 |  #5
In terms of most of thehandling, controls, and features, the 30D is very similar. The 5D has a few more features but how the cameras work are pretty much the same. The 5D is a touch bigger as well.
In terms of image qulaity, I don't think you'll notice much difference unless you print bigger than 8x10 though.
Gallery: http://tomyi.smugmug.c​om/ (external link)
chris ­ clements
Joined Mar 2004
Feb 26, 2007 05:18 |  #6
As you'll find if you do any searching here, the 28-135 is not a well-liked lens, and (sorry) a clear mismatch with the 5D. All 28-135's are of wobbly/flimsy build, and the optical quality is variable to say the least.
Obviously the 'L' route is the way to go if you have the moolah, but with your 35mm background you'll know of a slew of Sigmas and Tammys that can see this budget lens off comfortably.
nicksan
Man I Like to Fart
Feb 26, 2007 12:57 as a reply to  @ chris clements's post |  #7
5D isn't much different operationally speaking. Same controls. Same menus, etc...the 5D is missing the various P&S modes since that's not its target audience. Missing flash is another obvious one...same reason.
The real difference is in the resulting image!
Kevin034
Feb 26, 2007 13:18 |  #8
congrats on the best camera Canon makes ever.
5D > 1Dblah MKblah > everything else.
Kevin
MKIII/5D/24-70/70-200/50
1,273 views & 0 likes for this thread, 8 members have posted to it.
New 5D
1048 guests, 103 members online
