My Manfrotto 3021 tripod has a broken leg clamp on one of the legs. It makes it nearly impossible to adjust the leg height without prying it open using a screwdriver. Does anyone know if this is fixable or am I just stuck with it?
efroten Member 161 posts Joined Sep 2006 Location: Chicago More info | Feb 25, 2007 19:30 | #1 My Manfrotto 3021 tripod has a broken leg clamp on one of the legs. It makes it nearly impossible to adjust the leg height without prying it open using a screwdriver. Does anyone know if this is fixable or am I just stuck with it? http://www.awordlesschorus.com/blog/
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 25, 2007 19:43 | #2 Manfrotto will probably sell you the replacement parts. Check the Bogen website; IIRC they have a section on parts and/or user support. Jon
thescottandrew Senior Member 906 posts Joined Apr 2006 More info | Feb 25, 2007 19:53 | #3 Jon wrote in post #2774333 Manfrotto will probably sell you the replacement parts. Check the Bogen website; IIRC they have a section on parts and/or user support. dont know what else to do, thats the best advice i could give you
JWright Planes, trains and ham radio... 18,399 posts Likes: 35 Joined Dec 2004 More info | Feb 25, 2007 22:21 | #4 efroten wrote in post #2774258 My Manfrotto 3021 tripod has a broken leg clamp on one of the legs. It makes it nearly impossible to adjust the leg height without prying it open using a screwdriver. Does anyone know if this is fixable or am I just stuck with it? Been there, done that, same tripod. I actually had two Bogen tripods with broken parts. I contacted the Bogen parts center and they e-mailed me the parts diagram for the tripod. I was able to use this to determine which part I needed and I contacted them by phone to order the part (mine had a broken leg clamp lever). It took quite a while to get because the part was back-ordered, but I finally got it. Since I had to replace the lever anyway, I took the opportunity to completely disassemble the tripod and clean and lubricate all the parts. The diagram helped immensely in this. When I got the tripod back together, it worked just like new. John
FlashZebra This space available 4,427 posts Joined Mar 2006 Location: Northern Kentucky More info | Feb 25, 2007 22:38 | #5 I have personally ordered all sorts of replacement parts from Bogen to repair lightstands, booms, tripods, etc.
| Latest registered member is SteveeY 1713 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
