Thread started 26 Feb 2007 (Monday) 01:07
too much fill and light throught the shirt
azpix
Feb 26, 2007 01:07 |  #1
I was taking some pix of my wife this evening and used my 580 to fill. When I looked at the pix on my comp, in all of them you an see her bra through her shirt.
I've seen this before in pixs. Is there any easy way to avoid this when shooting and using a flash?
Thanks,
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
bigjon0107
Feb 26, 2007 01:12 |  #2
I am not sure because i have not had this problem, but i am assuming that you would just have to stop the flash down and use more ambient light, unless you needed that much flash due to the lack of available light.
-Jon
Jon Eilts
SportsShooter (external link)
psurrette
Gallery: 13 photos
Feb 26, 2007 01:17 |  #3
Is the photo overexposed? or is it the location of the fill causing the see through effect? Try changing the location of the 580 and see if that helps.
|SportsShooter Member (external link) | PeteSurrettePhotograph​y.com (external link) | Cameras: Fuji XT 2, Fuji XT 1 | Lens: Fuji: XF 10-24 f4, XF 16-55 f2.8 WR, XF 35 f1.4 R, XF 501.2, XF 50-140 f2.8 R, 100-400 f4.5-5.6 | Bags: Thinktank, Domke, Pelican | Feedback: 1-2-3
Curtis ­ N
Master Flasher
Feb 26, 2007 06:59 |  #4
The problem is those darn bras. Tell her to stop wearing them.
(sorry)
Anything you can do to move the flash further from the lens will help some. Bouncing the flash, using a flash bracket or a reflecting type attachment like the Lumiquest products or Joe Demb Flip-it.
capturedbymike
Feb 26, 2007 13:54 |  #5
Post some pictures to help us understand (just kidding)
It may also be the fabric she is wearing, try a different shirt.
Canon 30D, Canon 550D , Canon 28-135 IS, Canon 50mm f/1.4, Canon 70-200mm f/2.8 L IS, Canon 580 Flash, Shaky hand
www.capturedbymike.com (external link)
themirage
Feb 26, 2007 23:41 |  #6
- Diffuse the light by bounce, etc.
- The color of the bra makes a difference. She should be aware what color bra to wear with a certain color shirt.
-Michael
Designs of Utopia (external link)
SmugMug Gallery (external link)
˙ǝɹnʇɐuƃıs ʎɯ uı pǝʇsǝɹǝʇuı ʎllɐǝɹ ǝɹɐ noʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
DocFrankenstein
Joined Apr 2004
Feb 26, 2007 23:55 |  #7
It has nothing to do with 580 EX... it has to do with the shirt. I bet you could see the bra with ambient light as well.
Change the shirt.
National Sarcasm Society. Like we need your support.
wardie
Gallery: 12 photos
Feb 27, 2007 00:03 as a reply to  @ themirage's post |  #8
Bouncing the flash may not make a difference.
I was shooting photos of my SIL as she needed shots in her gym gear for her "The Biggest Looser" application (she didn't make the cut).
When we viewed the shots in CS2 she was extreemly shocked to see that her gym bra top had become transparent. I fact when viewed closely on the screen it could have been lingere. Without the flash there was no indication that it could have been so as it was fairly heavy material.
It seems that the flash reflected off her skin through her top and no matter what we tried we could not stop the effect. The only solution was natural light (daylight) or a different top.
Wardie
Wardie
40D w/Grip,
30D w/Grip, 24-70 f2.8L, 100-400L,
Accessories - Kenko Pro 300DG 2x, Sunpack 4205G Flash
Curtis ­ N
Master Flasher
Feb 27, 2007 06:01 |  #9
DocFrankenstein wrote in post #2781979 (external link)
Certainly the fabric is a factor, but I've seen a lot of pictures with on-camera flash that made women's tops appear more transparent than with ambient light. The weave of the fabric and the direct angle of the light passing through it combine to make undergarments more visible. Of course the color of the bra makes a difference, too. This is why they make bras in beige and brown.
azpix
Mar 02, 2007 10:15 |  #10
in the ambient light it was not visible.
thanks all for the comments.
Benji
Mar 02, 2007 11:53 |  #11
Most cloth is weaved, meaning it has thousands of small "holes" in between the strands of fabric. If a powerful light source is aimed directly into the fabric, the light will travel through these holes, strike whatever is behind them and bounce back into the lens. If the area behind the holes is white, it will bounce white back, if it is skin, the color of the skin will bounce back. The contrast between the two allows the viewer to "see" the undergarmet.
Also some blouses (especially white ones) are rather see through all the time, regardless of the lighting.
Benji
Titus213
Mar 02, 2007 16:16 |  #12
Get thee to thy local burka dealer....
Dave
Perspiring photographer.
iambyrdman
Mar 02, 2007 17:12 |  #13
(What a thread for my first post.) If it was a satin bra, that would make things worse(reflective). I'd say keeping your flash off axis from the camera is a good tip. After that I think this problem may be better fixed in wardrobe than in lighting.
"Byrdman"
KevC
Joined Jan 2005
Mar 02, 2007 18:19 as a reply to  @ iambyrdman's post |  #14
Try bouncing flash.
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
Baadil
Mar 03, 2007 11:30 |  #15
Titus213 wrote in post #2803841 (external link)
It seems very bad remark. Not the one coming from a professional in photography forum. Sad.
Canon EOS 400D Xti (Poor man's 1D,) Canon 50mm 1.8 II, Sigma 55-200mm f/4-5.6, Canon 18-55mm Kit; Canon 17-55mm 2.8 IS
4,630 views & 0 likes for this thread, 13 members have posted to it.
2248 guests, 126 members online
