Thread started 01 Mar 2007 (Thursday) 10:06
580EX flash on auto?
Yella ­ Fella
Mar 01, 2007 10:06 |  #1
I dont think i have ever tried this in auto? how do i know its set to auto?
I always have it set to high speed sync, or is it literally turning this off and its set to auto?
Ed - www.edwardlui.co.uk (external link) | modelmayhem (external link) | facebook (external link)
Canon EOS 5D x2 | Canon EF 35mm f1.4 L USM | Canon EF 50mm f1.2 L USM | Canon EF 85mm f1.2 mkII L USM | Canon EF 24-70mm f2.8 L USM | Canon EF 70-200mm f2.8 IS L USM |Canon 580EX mkII x2http://www.edwardlui.c​om (external link)
SirBrontes
Mar 01, 2007 10:38 |  #2
Unfortunately, the Canon 580EX does not support Auto mode.
Curtis ­ N
Master Flasher
Mar 01, 2007 10:43 |  #3
There is no "auto" mode on the 580EX. You can use it in E-TTL mode or manual mode (or TTL mode with film cameras). E-TTL is the flash metering system that your camera uses.
High Speed Sync, if enabled, will be used if your shutter speed is faster than 1/250. If your shutter speed is 1/250 or slower, having HSS enabled won't make any difference. HSS can be used in E-TTL or Manual mode.
chris ­ clements
Joined Mar 2004
Mar 01, 2007 14:35 |  #4
Yella Fella wrote in post #2795646 (external link)
Why ???
Do you only shoot daylight fill with your subject only a few feet away?
That's all it's good for.
1,085 views & 0 likes for this thread, 4 members have posted to it.
1612 guests, 138 members online
