Thread started 01 Mar 2007 (Thursday) 11:41
Using a flash only to trigger slave?
bieber
Mar 01, 2007 11:41 |  #1
I've got a quick question, if anyone knows the answer. I'm planning on shooting an event tonight with a 580EX on top of my camera as a primary flash, and a 430EX in wireless slave mode for backlighting. There will be times, though, where I'd like to use ambient light for the most part, but keep the backlight from the slave. Is there any way to have the 580EX not fire itself, but still set off the wireless slave it's connected to?
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
DaveG
Joined Aug 2003
Mar 01, 2007 12:27 |  #2
Yes. You can disable to flash pulse from the 580. Have a look through the flashes' instuction book to see the setting. By the way the 580 will continue to appear to "flash" as the first instructional pulse still needs to be sent out by the 580. E-TTL has two pulses, a short "Informational" pulse that tells the 430 how to behave, and then the second "Illuminate the subject" pulse. You are disabling that second pulse.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
bieber
Mar 01, 2007 12:39 |  #3
Thanks. I'll take a look at the manual when I'm out of school, but does anyone know the setting in question offhand?
1,134 views & 0 likes for this thread, 2 members have posted to it.
1612 guests, 138 members online
