I am using a 20D and a 430EX speedlite. I am trying to get the second curtain flash to work, using the camera custom settings but the flash fires at the start of the exposure AND the end of the exposure???
If I use the 2nd curtain controls on the flash unit, it fires at the end of the exposure OK.
Am I missing something or is this the way it works?
Thanks for any info you can give me
You should still get a preflash even when 2nd curtain is set on the camera. Are you sure you're not also setting the flash to manual mode by accident?
