Hi, I am new to photography, still learning. I have indoor lighting equipment and was wondering what you set your Iso to when your doing indoor portrait with a light system? By the way, I am using a Canon digital Rebel XT.
teeny Senior Member 820 posts Joined Sep 2006 Location: Alabama More info | Mar 02, 2007 19:51 | #1 Hi, I am new to photography, still learning. I have indoor lighting equipment and was wondering what you set your Iso to when your doing indoor portrait with a light system? By the way, I am using a Canon digital Rebel XT.
raven7 Member 79 posts Joined Sep 2005 Location: Illinois More info | Mar 02, 2007 20:08 | #2 I normaly use ISO 100 with my lighting equipment.
bieber Goldmember 1,992 posts Joined Dec 2006 Location: Bradenton, FL More info | Mar 02, 2007 20:08 | #3 Depends. If you want a really wide aperture for extreme depth of field, you might want to turn it up substantially. Otherwise, I'd try to stick to 400 or below (200 would probably be a good balance, if the lights are reasonably powerful) to avoid noise. EOS 20D w/ BG-E2 grip
Thanks for the quick replies. I have 2 alien bees 800's for my lighting.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | It doesn't matter which lights you are using. You want to use low ISO's for best performance and low noise. In my home studio I shoot at ISO 100 almost exclusively and when I go out with my camera I try to work at as low an ISO as possible but I do crank it up when I have to, and as long as I am getting great exposures the noise is low. Robert
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 03, 2007 01:30 | #6 bieber wrote in post #2804906 Depends. If you want a really wide aperture for extreme depth of field, you might want to turn it up substantially. Otherwise, I'd try to stick to 400 or below (200 would probably be a good balance, if the lights are reasonably powerful) to avoid noise. I think you meant a narrow aperture for extreme depth of field. "If you're not having fun, your pictures will reflect that." - Joe McNally
krazziecliff Senior Member 761 posts Joined Jan 2007 Location: Dubai, Mumbai and Goa More info | Mar 03, 2007 01:34 | #7 Maybe he means extreme, meaning really shallow....so wide would be the correct term to use.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 03, 2007 03:19 | #8 krazziecliff wrote in post #2806164 Maybe he means extreme, meaning really shallow....so wide would be the correct term to use. ...... but you would lower the ISO so that you could use a wider aperture. Skip Douglas
schulmat Hatchling 1 post Joined Mar 2007 More info | Mar 12, 2007 13:57 | #9 I am taking pictures indoors in a theatre an I cannot use a flash...What should I have for ISO? 1600 Should I have my aperture at its widest opening?
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 12, 2007 14:08 | #10 Hi Schulmat, welcome to POTN! schulmat wrote in post #2858889 I am taking pictures indoors in a theatre an I cannot use a flash...What should I have for ISO? 1600 Should I have my aperture at its widest opening? Depends on the lens, but 1600 is a good place to start, with the lens wide-open in Av mode. If you're using a fast prime like a 50mm f/1.4 you might be able to use ISO 800 or even ISO 400 if the light is really good. Use whatever ISO setting you need to get a decent shutter speed. I use ISO 3200 quite a bit with a 70-200 f/2.8 since I need a faster shutter speed with the longer focal length. "If you're not having fun, your pictures will reflect that." - Joe McNally
| Latest registered member was a spammer, and banned as such! 1745 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
