Hi everyone. I am new to the world of studio portrait photography and wanted to get some input on what lens is best suited for portrait photography? Thanks so much, Bo.
EOSimages Senior Member 273 posts Joined Mar 2006 Location: Texas State of Mind More info | Mar 03, 2007 09:08 | #1 Hi everyone. I am new to the world of studio portrait photography and wanted to get some input on what lens is best suited for portrait photography? Thanks so much, Bo. Bo
donlavange Goldmember 1,600 posts Joined Nov 2004 Location: Cumberland, RI, USA More info | Mar 03, 2007 09:12 | #2 On a full frame sensor, I love the 85mm F1.2. I have the Mark 1 but there is a faster focussing Mark 11 which you do not need for portraits. You should be able to get a real deal on a Mark 1! Don LaVange
kster Senior Member 551 posts Joined Jan 2006 Location: California, USA More info | Mar 03, 2007 09:17 | #3 I use the 70-200 f2.8 IS the most (also on a FF camera). Any of the 85mm lenses are also great (as Don mentioned). 1DmkIII and some lenses
Longwatcher obsolete as of this post 3,914 posts Likes: 3 Joined Sep 2002 Location: Newport News, VA, USA More info | I will add to the 85/1.2 as best lens for portrait work, "Save the model, Save the camera, The Photographer can be repaired"
rslv Member 233 posts Joined Jan 2007 Location: Denmark More info | Mar 03, 2007 12:40 | #5 Your gear list indicates that you like reasonably priced equipment - following that trend: "Good smell is good camera" - Dr Nakamats
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 03, 2007 12:46 | #6 The age-old recommended focal lengths for standard portraiture with 35mm film cameras has been a range of 80mm to 135mm, with the nominal standard at about 80mm. When comparing fields of view between 35mm film cameras and APS-C cameras such as your 300D, the recommended range translates to using 50mm to 80mm lenses with the emphasis near 50mm. Skip Douglas
donlavange Goldmember 1,600 posts Joined Nov 2004 Location: Cumberland, RI, USA More info | Mar 03, 2007 13:16 | #7 SkipD wrote in post #2807971 The age-old recommended focal lengths for standard portraiture with 35mm film cameras has been a range of 80mm to 135mm, with the nominal standard at about 80mm. When comparing fields of view between 35mm film cameras and APS-C cameras such as your 300D, the recommended range translates to using 50mm to 80mm lenses with the emphasis near 50mm. Thus, the recommendation of a 50mm f/1.4 Canon lens is a very good one for starters for use with APS-C format cameras (300D, 30D, etc.). Given enough light, your 18-55 zoom should be fine for getting started. The most significant difference between that and the 50mm f/1.4 (other than build quality, etc.) is the ability (using the f/1.4) to get a shorter depth-of-field to blur the background if that is desired. When stopped down to f/8 or so, the "kit" lens should be just fine. But remember that it is still a 50mm with the distortion of a 50mm. The length is gained by cropping, not a longer lense. The 50 is fine for 1.6 crop pics when you are back a little and on very young faces, but if you fill the frame and shoot an older person or one with an ample nose, you will not make a friend. . . and you will not sell a print! Don LaVange
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 03, 2007 15:03 | #8 donlavange wrote in post #2808133 But remember that it is still a 50mm with the distortion of a 50mm. The length is gained by cropping, not a longer lense. The 50 is fine for 1.6 crop pics when you are back a little and on very young faces, but if you fill the frame and shoot an older person or one with an ample nose, you will not make a friend. . . and you will not sell a print! There is no inherent "distortion" associated with any particular focal length except for specialty lenses such as fisheye lenses. Of course, some very cheaply made lenses will have more distortion than average lenses. Skip Douglas
tsaraleksi Goldmember 1,653 posts Likes: 1 Joined Sep 2006 Location: Greencastle/Lafayette Indiana, USA More info | Mar 03, 2007 15:07 | #9 SkipD wrote in post #2808630 The "distortion" you refer to really has nothing to do with focal length. What you are referring to is related to perspective. Perspective is totally controlled by the distance between the viewer (or camera) and the subject. Thank you! This seems to go back and forth with pedantry coming from the other side, despite their inaccuaracy! --Alex Editorial Portfolio
Mark_Cohran Cream of the Crop More info | Mar 03, 2007 15:19 | #10 This should help: Mark
chrishunt Goldmember 1,901 posts Likes: 3 Joined Jan 2005 Location: Denver, Colorado More info | Mar 03, 2007 15:31 | #11 |
steved110 Cream of the Crop 5,776 posts Likes: 2 Joined Dec 2005 Location: East Sussex UK More info | I'd suggest sigma 30mm f/1.4 ; Canon 50mm f/1.4 and Canon 85mm f/1.8 - they all make good portrait lenses, and give you the ability to go from tight head shots to small group without too much trouble. Canon 6D
JimAskew Cream of the Crop More info | Mar 03, 2007 17:37 | #13 steved110 wrote in post #2809178 I'd suggest sigma 30mm f/1.4 ; Canon 50mm f/1.4 and Canon 85mm f/1.8 - they all make good portrait lenses, and give you the ability to go from tight head shots to small group without too much trouble. There's no need to spend so much money on L primes - unless you a/ Want to and b/ can afford to ! Yep, and toss in the 100MMf/2.8 Macro and you will have the "Affordable Fab Four" primes all of which are excellent for taking portriats. I sure have fun doing so with mine Jim -- I keep the Leica D-Lux 7 in the Glove Box just in case!
elTwitcho frustrating as .... 1,478 posts Likes: 1 Joined Sep 2005 Location: Toronto More info | Mar 03, 2007 17:39 | #14 I use three lenses for my portrait work Rich
liza Cream of the Crop 11,386 posts Likes: 1 Joined Feb 2005 Location: Mayberry More info | Mar 03, 2007 17:42 | #15 Permanent banAlso consider the older, but still great Canon 28-70L. I also use the 85mm 1.8, the 100mm f/2, and the 70-200 f/4L for outdoor senior portrait sessions.
| Latest registered member is NekoZ8 1338 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
