Thread started 04 Mar 2007 (Sunday) 11:22
Older two pronged connector on flash
mntbikejack
Mar 04, 2007 11:22 |  #1
I have an older flash that I would like to use with an optical slave unit that has a PC connector. The flash has some type of two pronged connector on it to fire it with a cord.
What type of connector is it and are there cords that go from it to a PC connection? Below is a phot of the connection.
IMAGE: http://quantumpics.smugmug.com/photos/133564532-L.jpg
Thanks for your help!
Titus213
Mar 04, 2007 11:24 |  #2
I have an old Focal brand flash with that connector. The only cord I had for it was wired into the audio-trip box for tripping the flash with sound.
Dave
Perspiring photographer.
FlashZebra
This space available
Mar 04, 2007 12:05 |  #3
I would suggest checking out the Paramount Cord website and possibly giving Paramount a call.
http://paramountcords.​com/default.asp (external link)
It sort of looks like a female "Bi-Post" connector, but this is just a wild stab. And, most cords with a "Bi-Post" connection would be the same gender as you plug on the flash end, so would not work.
I am unsure if even the center to center spacing, or the pin diameter is the same as the "Bi-Post".
So, do not just go to Paramount and indicate you want a "Bi-Post" cords are you are likely to be disappointed.
If you have a good used camera store in your area ask to look at the sync cord "Hell Box". They all have one, with snake piles of all sorts of sync cords. I have personally looked through thousands of cords over the years. You might get lucky. I have.
You could also just forget the obtuse cord and get an inexpensive hotshoe to PC adapter that you could connect a more common cord to.
Enjoy! Lon
jmb4370
Mar 05, 2007 00:45 |  #4
Or you can send it to me...
I have added an auxilary sync jack and provied a sync cable to many diferent flash units.
See my site for more Information and contact help.
Michael
www.MichaelBassDesigns​.com (external link)
Michael
739 views & 0 likes for this thread, 4 members have posted to it.
2248 guests, 126 members online
