I resently used a the above combo in TTl mode using a 200th Sec shutter speed (which is the max sync speed for that camera) and my photos came out over exposed in the P mode. IE camers set in P mode I manually selected the shutter speed of 1/200th, the flash was in TTL auto mode. And all shots came out over exposed. I wasn't able to chimp in between shots so I didn't catch what happened until later. It was my first attempt to use a max sync speed as I just learned about it as my photography education was back in the 70's and then everything was 1/60th sec for flash and I have always used that when using a flash, but I just read an article on max sync speeds and read in the manual that for the 300D it was 1/200th sec. So I figured that if I set the speed to that then the ttl would tell the camera to use the correct apature vale for the shot. I figured if anything ewhen wrong the shots would be under exposed due tio the faster shuttler speed. but the reversed happened and the shots were overexposed by several stops. I haven't had the chance to shoot any more using the ttl mode and the max sync speed . SO what happened?
