Thread started 07 Mar 2007 (Wednesday) 17:42
Delta Flip Flash Bracket Question
baw5t0n
Mar 07, 2007 17:42 |  #1
I just got one and the supplied screw is way too long for the tripod mount on the camera... how did you guys install the bracket??
5D/BG-E4 || 28/1.8, 50/1.4, 85/1.8, 100/2.8 Macro, Sigma 17-35/2.8-4.0, 24-70/2.8L, 70-200/2.8L IS
COMPLETE GEAR LIST
My images. (external link)
Beski
Mar 08, 2007 08:42 |  #2
I just got this same bracket yesterday, and if I understand your question, I think I noticed the same thing when I put my camera on. The screw is too long, even when it's tight, there is still play in the camera.
This is the bracket I got from B&H:
http://www.bhphotovide​o.com …BFF1+&image.x=9​&image.y=5 (external link)
To fix my situation last night, I just put a standard "nut" (or you can use some spacers or washers) on the long supplied screw "before" I put in through the bottom of the bracket. The nut was slighly larger then the screw, but it did NOT have to "thread" into the nut, so the size of the nut is Not important as long as it's bigger then the screw, it just took up some of the screw's length like a spacer. Then less of the supplied screw actually stuck out of the bracket, so less went into the camera's tri-pod mount and when tightened, it was VERY SECURE !!
Hope this explanation helps and makes sense !!
Good Luck !!
1D Mark III | 40D | Rebel 300D
100-400L | 300 4L | 70-200 4L IS | 24-105L [COLOR=#800080]| 17-40L| 100 Macro | 10-22 | 85 1.8 | 50 1.8 II | 580EX
Curtis ­ N
Master Flasher
Mar 08, 2007 08:48 |  #3
I dunno about the Delta.
I had a similar issue with the Stroboframe CameraFlip, and I just put a washer under the screw head.
Picture in this thread.
In2Photos
Mar 08, 2007 08:56 as a reply to  @ Curtis N's post |  #4
There is a thread (or maybe just a post) specifically explaining some mods to the Delta Bracket to fix this and something else. I will keep looking for it.
EDIT: I found it:
https://photography-on-the.net/forum/showthre​ad.php?t=252335
Current Gear and Feedback
baw5t0n
Mar 09, 2007 20:22 |  #5
those are awesome step-by-step's. thank you for those.
COMPLETE GEAR LIST
1,881 views & 0 likes for this thread, 4 members have posted to it.
1745 guests, 120 members online
