Thread started 07 Mar 2007 (Wednesday) 20:37
EOS 5D + studio lighting - strong red bias on skin tones
photocat_uk
Mar 07, 2007 20:37 |  #1
After many years of owning various Canon prosumer digital SLR (D30, D60, 10D and 20D), I have recently upgraded to Canon EOS 5D. The new camera works perfectly, however my tests under studio lighting conditions indicate a very strong red bias on skin tones
I want to understand if this is a problem with a camera or if I am doing something wrong. I will provide full details below, but in a nutshell the camera exhibits a strong red bias on human skin under studio lighting conditions despite all attempts to achieve proper white balance
Conditions:
1) Camera body - Canon EOS 5D
2) Lenses - Canon 28-135 mm f3.5-5.6 or Canon 100 mm f2.8
3) Studio lighting setup - two Elinchrom Style FX400 compacts (rated at 5650 K) supplemented by a few Portaflash fill-ins. Softboxes on all main flashes.
4) Light balance - custom (using Jessops gray card) or explicit Color Temperature Compensation (set to 5700 K)
5) Control gray card shots indicate no problems with white balance
6) Color space - Adobe RGB 1998
7) Studio background - black velvet or white paper; studio walls are painted neutral pale yellow, no reflective or strong-colored surfaces within flash range
8 ) Ambient light - non-existent for all practical means and purposes (about 16 f-stops under main flash)
9) Model - caucasian female, blond, fair skinned, minimum make-up
10) Picture Style – 0 0 0 0
11) Aperture - around f/8
Problem manifestation:
1) The camera shows a significant red tint on all photographs which is particularly pronounced on the subject's skin
2) This tint is much stronger then I ever experienced with any other EOS camera body. It is also the “wrong color” from what I experienced before with EOSes - my previous bodies tended to have a slight yellow or blue tint, never red.
3) The RGB histogram indicates a strong red bias.
4) This bias could be compensated with a custom “Picture style”, but it requires a “Skin Tone” of 2 or 3 (out of -4 to +4 range). This appears to be excessive.
5) EOS 10D body demonstrates no such problem
I know that red-skin is a common problem for portraiture, but I have never experienced it so strongly under what is supposed to be highly controlled conditions.
Any help/advice would be greatly appreciated.
AmpedPhoto
Mar 07, 2007 20:43 |  #2
hum my 5D does great in studio. Are you shooting in RAW or JPEG? If your shooting in JPEG set the Picture styles to Faithful. if your shooting in RAW and not editing in Canons software it doesnt matter which Picture style you shoot in....
Canon 5D Mark II (x2), 30D, 40D, G10, 70-200 F4 IS (x2), 16-35 f2.8 L, 50mm 1.4, 430 EX II (x2), 580 EX II Tamron 28-75 F2.8 (x2), Tonkia 12-24 F4, 10-18 Fisheye, Full studio with some light :)
AmpedPhoto.com (external link)
sboerup
Mar 07, 2007 21:29 |  #3
Never had a problem with that. I shoot raw, leave it on "normal" picture style and process in DPP.
Is your color shift all normal, and your factory settings on the default? I can't imagine that being a sensor problem, just the internals.
Doug ­ Pardee
Mar 08, 2007 01:17 |  #4
You didn't mention which Picture Style you're using. Canon's "Portrait" picture style is rather notorious for producing pink-to-red skin tones; it's not clear if that's supposed to add color to pale skin, or maybe if it looks good with Asian skin. But whatever the reasoning, the result is still over-pink for most subjects at the default settings. The usual recommendation is to turn the saturation down one or two notches, and turn the color tone up one or two notches. Or just use another picture style, such as Faithful.
chtgrubbs
Joined Jul 2003
Mar 08, 2007 11:59 |  #5
There was quite a long detailed discussion of this problem on the Rob Galbraith forum last year. It was the consensus that it is due to the DIGIC II processor in the newer cameras. The best solution posted, which I use now, was to correct it in Photoshop. Make a Channel Mixer adjustment layer. Select the Green output channel and set it for Green-80% and Red-20%. Now select the Blue output channel and set it for Blue-90% and Red-10%. You can tweak the values to get the exact color you want.
It is a bit of bother to have to do this, but you can create an action if you have many images to correct. Here is a sample of the effect.
ninab
Mar 08, 2007 12:52 |  #6
chtgrubbs wrote in post #2837466 (external link)
Thanks! I've been working on my own little tweaks for this, but will try this one. Glad this is not another case of me "seeing things". :D
2x5D/grip; 24-70 f/2.8L, 85 f/1.2L II, 70-200 f/2.8 ISL, 70-200 f/4L, 15 fisheye, 28-200, Sigma 105 Macro, lensbaby 2.0; 580EXII, 580EX, 550EX
focusphototahoe.com (external link)
elTwitcho
frustrating as ....
Mar 08, 2007 13:18 |  #7
I'm glad it's not me either. I've noticed a reddish/magenta hue to skin tones that has been making colour balancing absolute hell. I'm going to give this a try and I'm pretty optimistic considering the two examples look pretty much just like how my shots look before correcting, and how I'd like them to look post correcting.
Thank you :)
Rich
Some of my recent projects
Portraits from 2007 (external link)
Urban Gallery (external link)
Where Toronto Was Built (external link)
People and such (external link)
ninab
Mar 08, 2007 14:13 |  #8
I tried this and ended up toning the corrections down a bit, the results were a tad too yellow; but it's a great way to deal with this! :)
Tixeon
Joined Oct 2004
Mar 08, 2007 17:57 |  #9
I had that problem also until I set Picture style to "neutral" in DPP when processing RAW to TIF.
Tim
______
Any cat owner will tell you -- no one really owns a cat...
DocFrankenstein
Joined Apr 2004
Mar 08, 2007 18:57 |  #10
Not owning a 5D, but knowing bits and pieces of color management theory my answer would be that the camera can't capture wrong color. There's an error in a processing step somewhere (look like the DigicII processor)
So you'll have to manually override the in-camera processing. You should be able to cure it by chooting raw and calibrating to a color checker like this (external link).
Hopefully if you're using third party RAW converter it would not be affected by the in-camera processing.
National Sarcasm Society. Like we need your support.
davidfig
we over look the simplest things
Mar 09, 2007 01:04 |  #11
Mine does great in the studio, oh wait, I set the custom white balance first. ;)
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
elTwitcho
frustrating as ....
Mar 09, 2007 09:40 |  #12
DocFrankenstein wrote in post #2839509 (external link)
With ACR it still comes up.
Through my experience, there is no color temperature that corrects this issue. I've used a white card/color checker (wahtever you want to call it) to set my white point off of, and there is still too much magenta in the skin tones. It isn't that all the colours are shifted in any one direction (something that can be fixed with colour balance) but rather the pinks are more saturated than the rest of the colours.
Rich
DocFrankenstein
Joined Apr 2004
Mar 09, 2007 10:23 |  #13
elTwitcho wrote in post #2842508 (external link)
Beats me then.
It'd be interesting to know what they suggested on rob gailbrath's forums as the solution.
ninab
Mar 09, 2007 11:56 |  #14
I applied this
to about 200 shots and it works great!!!! Just make an action and link it to a key, then it takes .2 seconds to apply
Thank you, chtgrubbs!:)
chtgrubbs
Joined Jul 2003
Mar 11, 2007 11:43 |  #15
You are very welcome.
8,616 views & 0 likes for this thread, 17 members have posted to it.
2706 guests, 167 members online
