Thread started 08 Mar 2007 (Thursday) 18:00
580EX Question
grinchy
Mar 08, 2007 18:00 |  #1
when the flash is in E-TTL does your camera need to be in evaluative mode for best results?
Body:
40D
Lenses:
Canon 50mm f/1.4
Canon 85mm f/1.8
Canon EF 24-105mm f/4
Misc:
580EX..Better Beamer..4 & 8gb Ridata 150X CF..Opteka Battery Grips..Kenko 1.4 TC..UV Filters..Lowepro Slingshot..Tripod
EOS ­ MAN1
Mar 08, 2007 18:27 |  #2
Any of the metering modes will work fine as far as I know. I think the metering works the same for flash. I have found that if you can't seem to nail the exposure you want, use the manual pre-flash/exposure lock button. It makes a difference in some situations. It is known that the flash fires a fast preflash on its own, but it doesn't always corespond with exactly what you want to meter. So every once in a while this helps.
I have used all the metering modes and they seem to work fine for flash.
BERNARD BRZEZINSKI
- Photography & Consulting Services
- http://www.bernardbrze​zinski.comexternal link | contact: nfo@bernardbrzezinski.​com
grinchy
Mar 08, 2007 18:37 as a reply to  @ EOS MAN1's post |  #3
ok cool that's what I was thinking but I was not 100% sure..anyways thanks for the info..:)
Body:
40D
Lenses:
Canon 50mm f/1.4
Canon 85mm f/1.8
Misc:
Curtis ­ N
Master Flasher
Mar 09, 2007 07:05 |  #4
There is an important concept that should be explained here. Every flash photo is a double exposure - an ambient light exposure and a flash exposure. The camera meters and adjusts for ambient light and flash exposure separately.
The camera's metering modes (Evaluative, CW Average, Partial, Spot) affect only the ambient exposure.
The way to change the flash metering mode is with custom function 14 (Evaluative vs. Average) and by using the * button for Flash Exposure Lock (which uses partial or spot, depending on the camera model).
There is somewhat of a consensus (though it's not unanymous) that C.Fn. 14-1 (Average) works best when flash is the primary light source (indoors), and C.Fn. 14-0 (Evaluative) works better for outdoor fill.
717 views & 0 likes for this thread, 3 members have posted to it.
580EX Question
1749 guests, 120 members online
