Thread started 08 Mar 2007 (Thursday) 19:46
Question re: Wide Angle lenses
BBoi
Mar 08, 2007 19:46 |  #1
What happens when you attach an 0.6 wide lens directly in front of a .5 wide lens ?
Anyone tried ? does it widen your shot or is a futile measure.
Quick Online Paint Prog for on-the-spot editing (external link) (requires flash)
>> Visit my Site (All Gold Photography Uk) All advice on the rebuild gratefully recieved. (external link) <<
All done with a Canon A640
boink
Mar 08, 2007 22:31 |  #2
bends space and time :(
I honestly don't know, sorry, hope the answer comes!
//Canon EOS 30D //Sigma 17-70mm
//Canon EF 70-300mm //Canon Speedlite 430EX
//Apple Macbook 13" (black) //Adobe Design Premium CS3
//full gear list + pictures
SkipD
Joined Dec 2002
Mar 09, 2007 03:50 |  #3
BBoi wrote in post #2839693 (external link)
I believe your question is regarding add-on adapters. Folks in this forum use SLR's with interchangeable lenses and generally do not use adapters like you are thinking of.
You would be more likely to get an answer in the point-n-shoot forums, in my opinion.
Skip Douglas
BBoi
Mar 09, 2007 08:37 |  #4
Can you point me at the P&S forum ? I don't seem able to find it, or see it.
thanks.
Jon
Joined Jun 2004
Mar 09, 2007 08:41 |  #5
You generally won't be able to since they each have a specific rear thread diameter and that's smaller than the front diameter. Even if you could, the image quality would be abysmal, since using only a single wide adapter will show distortion at the corners. Using two stacked would magnify this.
Jon
Cocker Spaniels
Saudidave
Joined Jun 2004
Mar 09, 2007 09:46 |  #6
SkipD wrote in post #2841480 (external link)
Someone is confused, he is in the P & S forum!
Panasonic TZ5 ;Canon IXUS 850; (Canon 400D, 17-85IS; 75-300; bag; filters and all that stuff given to my very clever daughter for passing her exams!)
JustShootin'
Mar 09, 2007 09:55 |  #7
Saudidave wrote in post #2842518 (external link)
That's what I was thinking, but then I just figured the thread had been moved here from somewhere else or something ?? :confused:
Gary
Canon SX40, S100 and a Non Canon dSLR
“Any darn fool can make something complex;
it takes a genius to make something simple.”—Pete Seeger
BBoi
Mar 09, 2007 10:09 |  #8
Yeah it was moved, my bad, when I saw the forum description of "Everything about accessories for Canon digital" I just clicked it - the EOS bit didn't register much since I wasn't speaking about EOS or pro DSLR gear at all, I figure even EOS users would probably be using the same filter-thread based addons.
Still, I know now.
Reason I asked is I have a wide lens at .5 and have seen in the local rag, a .6 which fits the .5's filterside thread. I was hoping for a much wider field spread. Still, don't find out unless you ask :) - and I have plenty more questions as I gather my gear.
Thanks chaps.
1,162 views & 0 likes for this thread, 6 members have posted to it.
2252 guests, 93 members online
