how do i use a grey card properly with my s2, i shoot a lot in "p" mode
brantfordbandit Senior Member 504 posts Joined Sep 2006 More info | Mar 08, 2007 20:13 | #1 how do i use a grey card properly with my s2, i shoot a lot in "p" mode canonguy
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 09, 2007 08:23 | #2 For WB; set WB to "Custom", aim the camera at the grey card, press "Menu" again and it's memorized. Should be explained at greater length in the "White Balance" section of your manual. But once you set a Custom White Balance, that is what will be used in Custom until you undo it. Jon
costas Hatchling 6 posts Joined Nov 2006 Location: UK More info | Hmmm - is that a trick question ! --------
Graystar Member 156 posts Joined Feb 2007 Location: Brooklyn, NY More info | removed
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 12, 2007 09:06 | #5 In fact Canon recommends using a grey, not a white, card for setting white balance, since "correctly exposing" a white card may blow one or more colour channels, throwing off your CWB setting. Jon
teekay Goldmember 3,037 posts Likes: 799 Joined Apr 2001 Location: British Columbia, Canada More info | Don't know about the S2 but my A95 manual says "a piece of white paper or cloth, or a photo-quality gray card". I would think that applies to other Canons as well.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 12, 2007 10:58 | #7 In the EOS models they say "Instead of a white object, an 18% gray card (available commercially) can produce a more accurate white balance." Jon
costas Hatchling 6 posts Joined Nov 2006 Location: UK More info | You can use any neutral surface to set white balance - the key word being neutral. Generally an 18% reflectance grey card is used for measing exposure and the white reverse from manufacturers such as Kodak for determining White Balance because this is more neutral. In practice the difference may be so slight it may not matter. --------
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 12, 2007 11:04 | #9 The white reverse side of a good 18% grey card is not "more neutral" than the grey side. Both are neutral. Either can be used; the danger with white is that you might blow out the channels. Jon
costas Hatchling 6 posts Joined Nov 2006 Location: UK More info | OK - should have done this in the first place --------
costas Hatchling 6 posts Joined Nov 2006 Location: UK More info | Well I thought I was following the instructions that came with the card Jon - should have read the camera manual more closely - took your mention to make me go and dig it out. --------
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 12, 2007 11:24 | #12 The 90% white side's offered for exposure metering in low light conditions or for use with a color balancing meter. It's a legacy of film. Jon
| Latest registered member was a spammer, and banned as such! 2553 guests, 98 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
