FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 09 Mar 2007 (Friday) 03:31
ZoomBrowser 5.x CameraWindow does not open
amplitron
Mar 09, 2007 03:31 |  #1
Hi,
I have installed a brand new ZoomBrowser EX v 5.7 supplied with my new G7 and the CameraWindow does not open. It flashes and disappears. ZB does not communicate with the cameras – I tried G7 and S50. Both cameras are perfectly recognized by the PCs. I upgraded to ZoomBrowser EX v 5.8a and still have the same problem. I have tried the software on two different WIN XP SP2 PCs and the effect is the same – no Camera Window. When using the ZB EX v 4.6 I have no problems whatsoever. Any suggestions how to make CameraWindow in Zoom Browser EX v 5.7 or 5.8 working ?
Greetings, Amplitron
MaxZoom
Mar 09, 2007 11:49 |  #2
For some reason the Canon service does not start automatically on some Windows XP systems. Try the following kick start and see if this is the case on your PC.
Right-click on "My Computer" elect manage (possibly 4th item down on list)
In the computer management console which opns select "Services and Applications" in the right hand frame by double-clicking it.
Double click on "Services" probably the first item in the right hand frame.
Scroll down to the service named "Canon Access Library 8", right click on it and select start. If start is disabled then the service is already started and you need someone better than me.
A dialog shoud appear for a few seconds saying "Starting..."
Try opening the CameraWindow again.
The next trick is to find some one who knows how to cure the non start situation. If anyone knows the permanent solution to avoid this kick start stuff, please share I for one would love to know.
Max :rolleyes:
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
amplitron
Mar 09, 2007 12:20 |  #3
Hi MaxZoom
Thanks for the reply. I already know the reason why the ZB 5.x does not work on some XP machines (thanks to Wklee on the DPreview.com forum). This is because ZB 5.x requires that the SSDP - Simple Service Discovery Protocol- was active. On some machines SSDP is diabled by the security software, and for a good reason.
To turn it back on you'll have to go to Start/Run/ and type services.msc. Find SSDP and turn it back on. This also makes your PC a little less secure because of the way it works - creates a security hole in the system.
This remedy worked for me, but as I said, compromises the security.
Greetings, JJ
Permagrin
Mar 09, 2007 12:36 as a reply to  @ amplitron's post |  #4
On our mac's the reason zoombrowser wouldn't open was because another program (in our case, aperture) over rode the command....so to me it sounds like a software issue. One of your photo programs is the "primary" program to open when a camera is connected. We solved this by reloading zoom browser and making it the one to open when a camera or card reader (and just closing it when we wanted to use aperture)...there should be an option upon loading that will say "make this your (whatever) program to open these files"
LoneEmperor
1 post
Nov 11, 2007 13:08 |  #5
This solved my problem with a PowerShot S5 on an XP system :D I suspect that the SSDP service was turned off by NOD32, the anti-virus s/w that I use and like a lot. Does anyone else have this combination?
amplitron wrote in post #2843203 (external link)
Hi MaxZoom
Greetings, JJ
Oldaggie
1 post
Dec 26, 2007 13:31 |  #6
Thanks for the help amplitron it work once I changed the setting Thanks again.
11,855 views & 0 likes for this thread
Latest registered member is mcsdet
1614 guests, 252 members online
