Thread started 09 Mar 2007 (Friday) 20:44
Saving changes to RAW files in DPP
Mike2005
Mar 09, 2007 20:44 |  #1
When you save change(s) to a Raw file in DPP without converting it to JPEG or TIFF, does the saving process do anything to degrade the original Raw file?
20D
17-40 f/4L
50 f/1.4
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 09, 2007 21:03 |  #2
No, What RAW converters are doing at that point is essentially saving a "recipe" for the changes you made, and they do so without making any changes at all to the actual RAW data.
Most RAW converters save this "recipe info" in a totally separate file, similar to a thumbnail database within each folder (RSP, C1 and BB dod this)
I can't recall where DPP saves the data, but in either case, the RAW Image is not changed.
CDS' HOT LINKS
Mike2005
Mar 09, 2007 22:32 as a reply to  @ CyberDyneSystems's post |  #3
Thanks.
20D
17-40 f/4L
50 f/1.4
yb98
Joined Feb 2003
Mar 10, 2007 00:38 as a reply to  @ Mike2005's post |  #4
I noticed that the size of the raw file increase a little, so it saves the converting parameter into the raw file itself. But it seems that these modifications don't change the raw file structure since ACR and C1 still can open the file.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 10, 2007 00:49 |  #5
Thanks yb, I was thinking this was the case with DPP, but could not recall as I haven't used it in ages. DPP actually attaches the recipe to the RAW file itself, which is handy for archiving etc.
With BB, C1 and RSP, if you don';t keep your RAW files in the same folders, all that info will be lost.
CDS' HOT LINKS
tzalman
Fatal attraction.
Mar 10, 2007 02:42 |  #6
Actually, with DPP you can choose between saving changes as an addition to the metadata or in a separate .vrd file.
Some people have suggested that writing to the metadata carries a risk of corrupting the file. I think this is a groundless fear; if Canon knows how to write the "as shot" settings to the file in-camera without affecting the RAW data, why wouldn't they know how to do it in DPP? BTW, when the changes are saved the "as shot" data is not overwritten and you can always return to it (Adjustment/Revert to shot settings).
Elie / אלי
yb98
Joined Feb 2003
Mar 10, 2007 03:44 |  #7
tzalman wrote in post #2846737 (external link)
Yes but it's just to bad that you have to do that manually.
Best DPP Threads
1,829 views & 0 likes for this thread, 4 members have posted to it.
1207 guests, 182 members online
