Thread started 10 Mar 2007 (Saturday) 17:43
question about off-camera bracket
SBCmetroguy
Mar 10, 2007 17:43 |  #1
I met a photog downtown today who was using one of these to take pictures of people. Every now and then I'll come across someone who is using one.
My question... when does this bracket become necessary? I typically just mount my flash to the hotshoe when I need it.
Thanks.
J ­ Rabin
Joined Aug 2004
Mar 10, 2007 19:54 |  #2
SBCmetroguy wrote in post #2849448 (external link)
...when does this bracket become necessary?
Answer: When you shoot 1) on-the-go, 2) a lot of flash events of people, 3) with camera in vertical portrait orientation. There are few substitutes for a flash rotation bracket. When I'm really on-the-go, I'll just use an Off-Shoe-Cord and hold the flash, otherwise a CB Jr., which is typical of the products out there.
Few people say it better than Chuck Gardener, so I'll just cut and paste a quote from his site:
"A single direct hot shoe flash regardless of where it is positioned will create sharply defined dark shadows because the size of the lightsource is small and there is no secondary light source to "fill" and modulate the tone of the shadows. A camera hot shoe locates a flash as close as possible to the lens axis to minimize shadows; just enough above the lens to prevent "red eye" reflections from the retinas of the person being photographed. That works OK in landscape mode, but when the camera is turned sideways into "portrait" orientation the flash moves down beside the lens which creates a harsh distracting shadows behind and to the side subject. Photographers learned to solve that shadow problem by raising the flash a foot or more directly above the lens with a bracket. When a flash is raised directly above the lens, the head shadow falls down behind the shoulders out of sight. The potentially distracting nose shadow falls below the nose in a full face view or behind the nose in an oblique view where is it barely noticed."
Here's his site: http://super.nova.org/​DPR/Design/ (external link)
Jack
Curtis ­ N
Master Flasher
Mar 10, 2007 20:17 |  #3
Jack's remarks represent the most important reason to use a bracket.
Another reason is redeye prevention. When you shoot in dark environments at some distance (say 20 feet), you can get redeye even with a hotshoe flash. A bracket raises the flash several inches higher to prevent this phenomenon.
A flash bracket will do more to improve the look of indoor flash shots than just about anything else. I rarely use a flash indoors without one.
SBCmetroguy
Mar 10, 2007 20:25 |  #4
Thanks for the explanations!
With the bracket, do you still turn your flash head toward the subject, or does it fire off to the side or above the subject?
Sorry if I'm making this more complicated than it should be. I understand the basic principle now, but I'm just curious about the direction of the flash when it's mounted on one of these.
J ­ Rabin
Joined Aug 2004
Mar 10, 2007 22:00 as a reply to  @ SBCmetroguy's post |  #5
...I'm making this more complicated than it should be...
Bouncing and flash rotation are not "mutually exclusive tactics." Flash sits on rotation bracket just like it would be in hotshoe. When you are in portrait orientation, it rotates, staying in same orientation. Go play with one at a shop.
I've been plenty times with flash in hotshoe, camera held portrait orientation, flash head rotated about 80 degrees-right, bouncing off ceiling. Bouncing depends on distance and color of bounce surface and exposure goal of photo.
Plenty good tutorials by Curtis here on POTN and other places about bouncing flash.
BTW, While a flash bracket can be a be honkin rig, one side benefit is when working big crowded events (like conferences), persons see you, know you're a photog there to make the shot, and they move the hell out of the way, and don't interfere with getting the photo and doing the job!
Jack
SBCmetroguy
Mar 10, 2007 22:10 |  #6
Ha, thanks for the reply Jack! :)
I think I'll eventually end up investing in one. I can truly see the value of it now. I honestly thought it was virtually useless... mostly something to be seen with rather than for functionality.
I appreciate the help.
Lonnie
Joined Feb 2006
Mar 10, 2007 23:12 |  #7
What bracket do you use Curtis?
My YouTube Vlog: https://www.youtube.co​m/c/GarageFlips (external link)
Curtis ­ N
Master Flasher
Mar 11, 2007 06:45 |  #8
I use the Stroboframe CameraFlip (external link). It sells for around $75 at B&H. There are more expensive brands out there, but this gets the job done. Note that it won't work with a battery grip or a 1D series camera.
If you decide to buy one, there are a few assembly tips in this thread.
Lonnie
Joined Feb 2006
Mar 11, 2007 10:59 |  #9
Why won't it work with a grip? Does it attach at the tripod mount only?
kenwood33
Mar 11, 2007 11:50 |  #10
lhoney2 wrote in post #2852736 (external link)
Because there is not enough space for the camera to turn if a grip is attached.
I used the bracket in my sig and it works with a grip.
Gearlist
Curtis ­ N
Master Flasher
Mar 11, 2007 12:03 |  #11
I don't know where else you would attach one. ;)
When you look at the picture in vertical orientation, you can see that there isn't much room between the end of the sync cord on the hotshoe and the handle of the bracket. A grip has its own tripod mounting hole, but it adds too much height to the camera to fit on this bracket.
Modine
Location: Gaffney, S.C., USA. Home of the Big Peach water tower!
Mar 11, 2007 16:30 as a reply to  @ Curtis N's post |  #12
You may be using the wrong bracket. I use a Stroboframe.
Attach the battery to the BOTTOM of the Stroboframe (if you're using a Quantum or something similar). That will allow for a grip on the bottom horizontal part of the bracket.My Stroboframe allows me to move the part that holds the flash upwards about another 3/4", allowing for the battery grip.
Curtis ­ N
Master Flasher
Mar 11, 2007 18:32 |  #13
Modine wrote in post #2853918 (external link)
There are eleven different Stroboframe (external link) models, and a lot of diversity among them. Some accomodate a battery grip, some don't.
The simple styles like the Stroboframe Quick Flip (external link)will work with a grip, but the way they turn the flash sideways makes them incompatible with certain modifiers like the Lumiquest products and are awkward at best when used with a tripod.
Modine
Mar 11, 2007 20:38 as a reply to  @ Curtis N's post |  #14
Curtis,
Thanks for the info. Though I do not use any modifiers with my Stroboframe, I hadn't given that any thought.
SkipD
Joined Dec 2002
Mar 11, 2007 21:58 |  #15
I will be purchasing a Camera Flip soon and fully intend to modify it so that my 20D with grip will work properly. I realize there will be a slight offset of the flash-above-lens alignment in "portrait" mode, but I am fully willing to live with that small problem. I intend to make an extension for the connection between the handle and the base. When I have it done, photos will be available.
Skip Douglas
2,219 views & 0 likes for this thread, 7 members have posted to it.
1745 guests, 120 members online
