Thread started 12 Mar 2007 (Monday) 18:13
Lighting COnundrum
symes
Mar 12, 2007 18:13 |  #1
Hello Folks,
I want to set up my black background and put a light on the groud shining up to create a lit background than I want the Shadow of the model on the background...
what are your suggestions to accomplish this...
cheers,
Matt
Symes
Symplicity Photography (external link) Symplicity Glamour (external link)
5D Mark II; 1D Mark II; 17-40L; 24-70 2.8L; 70-200 IS 2.8L
DaveG
Joined Aug 2003
Mar 12, 2007 22:22 |  #2
symes wrote in post #2860105 (external link)
Hello Folks,
cheers,
Matt
It is almost a contradiction of requirements. You take a black background and if you put enough light on it it'll turn grey. Then you need to light something with enough brightness so that it'll show a recognizable shadow on the (now) grey backdrop.
Why don't you start with a white or light grey backdrop in the first place? Then you won't have to light it. It'll be roughly the same grey as the properly lit black background, without much pain. Then you can light the subject and have that subject's shadow fall on the background. If the shadow is black and the background grey or white then there should be some contrast. Starting with a black background for this just doesn't make sense.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
symes
Mar 12, 2007 23:20 |  #3
well I am going to try to do it with the white background first...which I assume is as simple as pointing the light from the front and not blowing out the back...
Cheers,
Symes
898 views & 0 likes for this thread, 2 members have posted to it.
Lighting COnundrum
1590 guests, 117 members online
