I just got my AB's 800 and the Umbrella bounce.
I'm not ready for the expense of a softbox so I was considering a 48" Brolly box.
Any one use this and getting a good result?
hannaxt Senior Member 367 posts Joined Feb 2007 Location: New Orleans, LA More info | Mar 12, 2007 23:45 | #1 I just got my AB's 800 and the Umbrella bounce. 5DMKII •EF50mm f1.4 •EF85mm f1.8 • EF100mm f/2.8 ISL • EF17-40mm f/4L •EF24-70mm f/2.8L •EF70-200mm f/2.8 ISL
Longwatcher obsolete as of this post 3,914 posts Likes: 3 Joined Sep 2002 Location: Newport News, VA, USA More info | Mar 13, 2007 09:45 | #2 About the only product I don't give a recommend to from AB is the brolly box. "Save the model, Save the camera, The Photographer can be repaired"
Stackinchips Member 237 posts Joined Aug 2006 Location: San Francisco, CA -SOMA- More info | Mar 13, 2007 11:01 | #3 Longwatcher wrote in post #2863578 I also tend to like that they quietly update their products based on customer feedback without advertising the upgrades. that is true. just got a vagabond 150 in yesterday, and there was a loose piece of paper in the box (not manual) mentioned an updated converter. Canon 24-70 F/2.8L
Longwatcher obsolete as of this post 3,914 posts Likes: 3 Joined Sep 2002 Location: Newport News, VA, USA More info | Mar 13, 2007 13:54 | #4 Stackinchips wrote in post #2863895 that is true. just got a vagabond 150 in yesterday, and there was a loose piece of paper in the box (not manual) mentioned an updated converter. I wish you hadn't told me that "Save the model, Save the camera, The Photographer can be repaired"
Stackinchips Member 237 posts Joined Aug 2006 Location: San Francisco, CA -SOMA- More info | Mar 13, 2007 13:58 | #5 hows that battery holding up after 3 years? Canon 24-70 F/2.8L
Mar 13, 2007 14:00 | #6 Longwatcher wrote in post #2863578 About the only product I don't give a recommend to from AB is the brolly box. As far as results it works well (even when broken), but it is way too flimsy for all but the most careful photographers and I am way too hard on my equipment. If you are careful putting it on, it works well, but I have to recommend you look around for other brolly box options first. Meanwhile, I love AB lights, stands and light mod kits and think the softboxes and umbrellas are good for the price and the radio remotes are also fairly good (although these could be made a bit sturdier). And I think AB customer service is fantastic. I also tend to like that they quietly update their products based on customer feedback without advertising the upgrades. Thanks, that helps me a lot. I'm trying to get some difused light and the bounce umbrella (white side) is still a bit harsh and my space is limited so I can't place it further away. 5DMKII •EF50mm f1.4 •EF85mm f1.8 • EF100mm f/2.8 ISL • EF17-40mm f/4L •EF24-70mm f/2.8L •EF70-200mm f/2.8 ISL
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | You can make an inexpensive DIY diffusion panel or get something like the LightingMagic.com diffusion panel Robert
Mar 13, 2007 20:21 | #8 TMR that looks like a viable solution for sure. 5DMKII •EF50mm f1.4 •EF85mm f1.8 • EF100mm f/2.8 ISL • EF17-40mm f/4L •EF24-70mm f/2.8L •EF70-200mm f/2.8 ISL
Longwatcher obsolete as of this post 3,914 posts Likes: 3 Joined Sep 2002 Location: Newport News, VA, USA More info | Mar 14, 2007 10:29 | #9 Stackinchips wrote in post #2864741 hows that battery holding up after 3 years? The battery on my Vagabond CU-300 is holding up well, but I followed the rules and it stays plugged in except when I use it. Although it gets what I would consider light use. It is starting to slow down a bit, which is why I picked up a spare battery for this summer "Save the model, Save the camera, The Photographer can be repaired"
BigMike Goldmember 1,023 posts Joined May 2006 Location: Edmonton More info | Mar 14, 2007 11:09 | #10 Thanks, that helps me a lot. I'm trying to get some difused light and the bounce umbrella (white side) is still a bit harsh and my space is limited so I can't place it further away. Actually, the light will get softer as the light source gets closer to the subject. It's the relative size of the light source that makes a difference...so farther away means a smaller source. Instructor at The Canadian Photography Learning Centre
| Latest registered member is ANebinger 990 guests, 177 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
