Thread started 13 Mar 2007 (Tuesday) 21:01
Swapped S1 IS for S3 IS now what?
wickiup
Mar 13, 2007 21:01 |  #1
Have acquired an S3 due to S1 malfunction. Is there a problem using the 52mm accessory tube and my existing 52mm lenses, etc. instead of rebuying all 58mm stuff?
Thank you
wickiup
mishnogram
Mar 13, 2007 21:05 |  #2
If it fit the S1, it won't work with the S3 so you'll probably end up buying all new things for the S3 anyways. I'd verify that for sure but that's what I was told when buying for my S2
Min
Canon Rebel xt with kit len, Sigma 55-200mm F4-5.6 DC, Canon S2IS, & not enough time to use them all.
http://picasaweb.googl​e.com/mishnogram (external link)
bpickles256
Mar 13, 2007 21:32 |  #3
If your 52mm S1 lens adaptor doesn't ft the new S3, just buy a new lestube from Lensmateonline.com. Then you can use you 52mm accessories with the new S3.
bpickles256
Mar 13, 2007 21:32 |  #4
wickiup
Mar 13, 2007 23:19 |  #5
bpickles256 wrote in post #2867078 (external link)
The new tube should be here tomorrow from Lensmate but I just had a case of afterthought jitters I guess.
wickiup
Thomas ­ S.
Mar 15, 2007 18:11 as a reply to  @ wickiup's post |  #6
You might encounter some problems with using the converter lenses from the S1 with your S3. I have heard that they arent as compatible as one would think.
Let us know how it does work though.
Regards
...Thomas
Canon 40D w/ EF-S 17-85IS USM | 50 1.4 | 70-200 f4L | 580EX II
Olympus OM1 (1970)
Praktica FX3 (1957) w/ Westanar 2.8/50 & Takumar 4/50 (I miss you grandpa)
wickiup
Mar 16, 2007 22:20 as a reply to  @ Thomas S.'s post |  #7
My S1 tube will not fit the S3.
There are two adaptor tubes available for the S3 and I chose the 52mm one in order to utilize the accessories I already had for the S1.
wickiup
1,598 views & 0 likes for this thread, 4 members have posted to it.
1739 guests, 171 members online
