Thread started 13 Mar 2007 (Tuesday) 23:35
How can I trigger 2 flashes off camera?
zoti
Mar 13, 2007 23:35 |  #1
I would like to set up 2 flashes off camera. One is a 430EX. The other is a Sunpak 383 super. The Sunpak has sync input so it's easy to trigger with just a long sync cord. I don't want any of the flashes to sit on the camera's hot shoe. The camera is a 30D.
The question is, how do I trigger the 430EX? I was thinking some sort of photoelectric trigger would work or maybe a sync cord splitter if it exists?
http://www.TomerLitvin​.com/ (external link)
René ­ Damkot
Mar 14, 2007 03:53 |  #2
It exists:
IMAGE: http://www.hama.de/bilder/00006/abs/00006963abs.jpg
IMAGE LINK: http://www.hama.de …rticleId*3985/a​ction*2563  (external link)
(click image)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
HenryS
Mar 14, 2007 05:00 |  #3
But the 430EX doesn't have a sync socket or does it? Photoelectric triggers generally don't work with Canon flashes. You could try a flash extender cable.
René ­ Damkot
Mar 14, 2007 05:12 |  #4
Or something like this:
IMAGE: http://www.hama.de/bilder/00006/abs/00006952abs.jpg
zoti
Mar 14, 2007 11:04 |  #5
Thanks.
HoRnYTuRbO
Mar 14, 2007 15:07 |  #6
HenryS wrote in post #2868567 (external link)
you're correct it doesnt have a sync socket
-Vinny
cosworth
I'm comfortable with my masculinity
Mar 14, 2007 15:11 |  #7
my ebay sourced Sonia trigger works flawlessly.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
zoti
Mar 14, 2007 16:05 |  #8
cosworth wrote in post #2870804 (external link)
I got something similar at Ritz Camera today. It works fine on my Sunpak 383 Super but will only trigger the 430EX once. After the first time I have to turn the 430 off and back on again. It will trigger once more and then off/on again. :(
Do you use the Sonia with a 430?
cosworth
Mar 14, 2007 16:08 |  #9
I use it with a 580 set to manual.
FlashZebra
This space available
Mar 14, 2007 16:10 |  #10
I have several Sonia optical slaves, and although they work just dandy with all sorts of flash units, I cannot get them to function properly with a Canon 550EX.
I am very surprised you could get a Sonia to work with a 580EX (or 430EX).
Enjoy! Lon
FlashZebra
Mar 14, 2007 16:18 |  #11
zoti wrote in post #2867692 (external link)
The Canon units are very annoying when you are trying to use them in basic manual mode off camera without loading up exclusively on several very expensive Canon units (ST-E2, 580EX, etc)
I suggest this as the path of least resistance (basic setup annoyance) and cost.
  • A hotshoe to PC adapter as shown in the post by René Damkot for the 430EX (set to manual mode)
  • A 15 foot PC male to PC female sync cord connected to the hotshoe adapter above.
  • An optical slave for the Sunpak 383.
Enjoy! Lon
zoti
Mar 14, 2007 17:36 |  #12
My problem is that the only thing I could find locally was the opticat slave. If it worked then my problems were solved. I'd have the sunpak connected to the camera with the sync cord and the 430 slaved with the optical slave.
If only the optical slave worked with the canon. I just can't understand why it works only once.
zacker
Joined Jan 2005
Mar 14, 2007 17:46 |  #13
there are a number of great sits on this.. strobists for one, prolly the best off cam small flash site going.
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
FlashZebra
Mar 14, 2007 21:51 |  #14
zoti wrote in post #2871545 (external link)
This issue has been the source of many threads on this forum, over many months.
If you have interest check out the search feature.
The issue is complicated and despite a lot of educated conjecture and some investigation there is no integrated and comprehensive answer to this issue.
But for now, you will not be able to get your optical slave to work with your Canon Speedlight.
So, run a cord to the Canon 430EX and slave the 383.
Enjoy! Lon
zoti
Mar 15, 2007 15:22 |  #15
Inspired byt the mod done for the 580EX I'm now adding an external sync port to the 430. It should be done tonight and I will post pictures.
4,185 views & 0 likes for this thread, 10 members have posted to it.
1592 guests, 117 members online
