FORUMS Post Processing, Marketing & Presenting Photos Presentation & Building Galleries
Thread started 14 Mar 2007 (Wednesday) 14:33
how to do this: adding an image then go to index
azpix
Mar 14, 2007 14:33 |  #1
I saw this on www. marktucker.com
when you go to the url, an image comes up for about 10 seconds then takes you to his index page.
Anyone know how this is done?
thanks
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
CrazyPuma
Joined Jun 2005
Mar 14, 2007 18:20 |  #2
If you View Source on that front page, it looks like he's using a meta tag to initiate a sort of redirect command ("refresh").
Canon EOS 20D / EF100mm F2.8 USM Macro / +the kit lens that I now feel like throwing away.
Technically challenged, cheap, and lazy ...http://photos.crimsonk​eep.com/ (external link)
IIIMik3
Joined Jun 2003
Mar 14, 2007 22:56 |  #3
Actually, all they did was they made the image a link. The page w/ the image is the index.html file, the page it goes to when you click the link/picture is index2.html.
So all you would do is change your main content page to index2.html, then create an index.html file w/ this in the code:
<a href="index2.html"><img src="whatever.jpg"></a>
Replacing the "whatever" as fit.
Model Mayhem Profile (external link)
www.charlesmichaelphot​ography.com (external link)
CrazyPuma
Joined Jun 2005
Mar 14, 2007 23:57 |  #4
Yes, there's an image link, but the page switches even if you don't click the image; just wait 10 seconds or so.
I would assume he made the image a link in case someone was using a browser/had setting where the auto-switch failed.
azpix
Mar 15, 2007 14:50 |  #5
thanks all.
I see that link and think I can pull that off. Now I'm trying to fgure out how he did the auto switch after the delay.
Would that be the jave script i see in his source code?
Thanks,
CrazyPuma
Joined Jun 2005
Mar 15, 2007 15:41 |  #6
No, it's just the meta tag that's inserted between the "head" tags. I inserted one into a quick and dirty test page (external link) and set it for 5 seconds and it seems to work fine.
so you want
 <meta http-equiv="Refresh" content="5; URL=http://your-domain-name/your-redirected-page-location.html">
The number after "content" defines how many seconds you want the delay to be.
It's not done with a single html file - you have to make two, and insert the meta tag on the first page, not the one that shows up after the delay.
IIIMik3
Joined Jun 2003
Mar 15, 2007 17:22 |  #7
ah, i guess i was too impatient to wait :)
1,286 views & 0 likes for this thread, 3 members have posted to it.
1013 guests, 112 members online
