Thread started 14 Mar 2007 (Wednesday) 15:50
Can I set focus level in 20D autofocus mode
chartbin
Joined Jul 2004
Mar 14, 2007 15:50 |  #1
More specifically, can I fine tune the level of sharpness in the 20D when I use the autofocus mode?
Nothing in the Menu looks obvious to me:confused:
http://m2moi.deviantar​t.com/prints/ (external link):lol:
crn3371
Mar 14, 2007 16:47 |  #2
Can you fine tune auto focus? No. Can you manually fine tune focus after achieving auto focus? Yes. There are no menu adjustments for auto focus. You can tell the camera which focus point to use, but that's it. Are your pics out of focus? If they just aren't sharp in the view finder, play with the diopter adjustment.
KevC
Joined Jan 2005
Mar 14, 2007 17:04 as a reply to  @ crn3371's post |  #3
If your lens has ringUSM that usually means you have full time manual focus (FTMF). You can "tweak" the focus while in AF.
If not, just switch the AF to MF and turn the focus ring.
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
chartbin
Joined Jul 2004
Mar 14, 2007 17:55 |  #4
Here are some test shot at f2.8 and f16.0
They look ok here, but my shots are usually soft-focussed, bugs me!:(
Jon
Joined Jun 2004
Mar 15, 2007 14:05 |  #5
Post some examples with EXIF data.
Jon
Cocker Spaniels
rowdyred94
Mar 15, 2007 14:35 |  #6
What lens? A 2.8 max lens won't be razor sharp at 2.8.
~ Clint :: Galleries (external link) :: Marketplace Feedback (external link)
chartbin
Joined Jul 2004
Mar 15, 2007 15:05 |  #7
How to attach with EXIF data?:confused:
I used a Tamron zoom 28-70 mm at 70mm.:)
chartbin
Joined Jul 2004
Mar 15, 2007 15:08 |  #8
I found the "parameter set 1 to 3" setting. Any exprience with them?
I did not see much difference, if any.
I set parameter set3 to have the highest sharpness setting.
StewartR
"your nose is too big"
Mar 15, 2007 16:13 |  #9
chartbin wrote in post #2871640 (external link)
...but my shots are usually soft-focussed
So show us some examples. There are loads of reasons why your shots might be soft focussed, and without being able to see them we have no way of helping you.
EXIF data is automatically attached to your photos by the camera and is preserved by most software packages. Don't use 'Save for web' in PhotoShop because that removes it.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
chartbin
Joined Jul 2004
Mar 15, 2007 17:54 |  #10
Thanks, StewartR. Here goes...
StewartR
Mar 15, 2007 18:35 |  #11
OK, the EXIF says f=32mm, 1/125th @ f/9. One thing that sometimes causes "softness" is camera shake, but we can rule that out here. (And the softness in the picture doesn't look like camera shake.)
Next, DOF is sometimes an issue. However in this picture there's nothing that is precisely sharp so it's not just DOF that's the problem.
Here's one suggestion though, which is related to DOF. I'd judge that the horses are about 0.5m from the camera. Then DOFMaster (external link) says the DOF is (roughly) +/-4cm, which isn't much. Were you using a tripod? If not, it's possible that you might have moved a few cm between getting the focus lock and taking the shot, and that would be enough to throw everything slightly OOF.
Other suggestions: Were you inside the minimum focussing distance for your lens? Have you sharpened the picture at all after it came out of the camera? (DSLRs are designed so that images need some sharpening...)
Here is another thread where a forum member had focussing issues which might be similar to yours.
chartbin
Joined Jul 2004
Mar 15, 2007 19:32 |  #12
StewartR wrote in post #2877460 (external link)
YES
YES
NO, this last statemt I have heard about DSLR especially 2oD, is there a way around it?:)
twebster
Account closed at Users request
Mar 16, 2007 04:16 |  #13
You can change the amount of in-camera sharpening through the parameter settings. However, I do not find the Canon sharpening algorithms to be all that good. Sharpening the image should be the last step in your post-exposure processing work flow. The amount of sharpening applied to an image will vary depending on the size and resolution of the final image. If you set the 20D to apply some in-camera sharpening then later on resize the image and sharpen again, you run the risk of creating over-sharpening artifacts, the little halos around subject details. You can set some in-camera sharpening but I would recommend against it.
Tom Webster
Tom Webster Photography (external link)
Gift Store (external link)
overclock
Joined Jan 2005
Mar 16, 2007 09:54 |  #14
Try the test again and focus on a particular part of one horse, like the eye for example. Then do a 100% crop and post that. A 100% crop is where you would just crop out a section, say 400x400 or so of the picture and just post that without resizing or reducing the quality.
3,364 views & 0 likes for this thread
Latest registered member is Lettuceboy95
925 guests, 253 members online
