Can anyone tell me if I can sync with a main power small flash unit via an optical slave. Canon tells me 350D is a Mum & Dad camera and not ment for this type of thing Any help would be appreciated Thanks
beckett Mostly Lurking 17 posts Joined Mar 2007 Location: Adelaide More info | Mar 15, 2007 07:18 | #1 Can anyone tell me if I can sync with a main power small flash unit via an optical slave. Canon tells me 350D is a Mum & Dad camera and not ment for this type of thing Any help would be appreciated Thanks
zeddy Member 155 posts Joined Feb 2007 Location: Essex, United Kindom More info | Mar 15, 2007 07:44 | #2 Not entirely sure what you mean. Do you want to fire an extrnal flash wirelessly? If so this is possible if you have a 580EX - it can trigger slaves. -Martin (flickr
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 15, 2007 08:23 | #3 Hi Beckett, welcome to POTN! "If you're not having fun, your pictures will reflect that." - Joe McNally
Mar 16, 2007 03:27 | #4 I have a 180w flash unit mains powered connected to a sync cord with a small optical trigger on the sync cord. The built in canon flash fires and triggers the main powered unit but no sync even a photo of the flash show no light on the studio main unit. Sorry not quite sure how to explain this had F2 before and no problems for 15 years Help
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 16, 2007 05:53 | #5 The camera's built-in flash fires a pre-flash before the shutter opens. This is part of Canon's E-TTL metering system. This preflash is triggering your main prematurely. "If you're not having fun, your pictures will reflect that." - Joe McNally
Thanks I give that a try. Cheers What is the next camera up that has a PC socket or should I just save up for a better flash unit?
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 16, 2007 06:15 | #7 The 30D has a PC socket. But if your 350D is otherwise meeting your needs, an inexpensive hotshoe-PC socket adapter like this "If you're not having fun, your pictures will reflect that." - Joe McNally
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 16, 2007 06:25 | #8 Curtis N wrote in post #2880052 The 30D has a PC socket. But if your 350D is otherwise meeting your needs, an inexpensive hotshoe-PC socket adapter like this .... along with fully manual exposure settings on the camera. Skip Douglas
zacker Cream of the Crop 6,006 posts Likes: 7 Joined Jan 2005 Location: Oxford, CT. More info | Mar 16, 2007 06:37 | #9 Pocket wizards or ebay cheap triggers.. use an older flash which has manual settings and learn to use the manual settings on your camera... prolly worth it to learn anyway, some day you'll prolly wanna know how so, no better time than now... no? http://www.theanimalhaven.com
Mar 16, 2007 22:19 | #10 Thanks everyone for your help I'll get a trigger and look at a 30D 20D or old 10D which do you think is better valus for money. When and If I ever get any money after buying a 70 -200 IS f2.8 which I love almost as much a s life and a 17 - 85 is f4/5.6
| Latest registered member was a spammer, and banned as such! 1592 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
