This is a question that I've been curious about for a while. It pertains to light absorption and factors that will contribute to greater absorption.
The question is this: Since we know that black absorbs the most light then I'll use black for this question. If I use black seamless it absorbs and reflects a certain amount of light. The surface of the paper is smooth with no texture or thickness to it. So.. if I then use a heavy black velvet curtain that is pleated and has texture and contour, does the addded surface area of the folds and texture add to its absorption?
An analogy to better explain.. When I design and build a recording studio one of the ways that we control the reflection of sound is to absorb it using various products designed to soak up huge amounts of sound and reduce reflection. Acoustic tiles that have large peaks and valleys with great depth are used because the design allows them to absorb about 400% more sound than a flat tile of the same size. These peaks and valleys are actually increasing the surface area, allowing for this dramatic increase in sound absorption.
Does the same thing apply to light? Will a textured black surface absorb more light then a completely flat surface?
It works the same way as the acoustic tiles. There's no large reflective surface on the velvet to bounce the light back. The paper is flat and smooth...might as well
