Thread started 16 Mar 2007 (Friday) 06:12
Possibly dumb question about Sunny f/16 and focal length
Rawling
Mar 16, 2007 06:12 |  #1
OK, there' something I'm a bit confused about.
The Sunny f/16 rule sats, if I recall, if you shoot in sunny weather at f/16 you use a shutter speed of 1/ISO to get correct exposure (roughly).
Doesn't focal length affect exposure? If I shoot a scene with a wide-angle lens, and then switch out for a telephoto, isn't there suddenly a lot less light hitting the sensor because there's a much smaller area being imaged? (That's assuming roughly constant brighness over the whole scene.)
Or is there something about lens construction/physics/a​perture etc. I've missed that says no, when you zoom in the amount of light hitting the sensor doesn't drop off.
Confused, would we?
In the bag: Canon EOS 350D | 18-55mm (kit) | 70-200mm f/4 L | 17-40mm f/4 L | 100mm f/2.8 USM macro | Speedlite 580EXII
In the pipeline: No idea. Suggestions?
SkipD
Joined Dec 2002
Mar 16, 2007 06:33 |  #2
Rawling wrote in post #2880047 (external link)
Confused, would we?
Focal length has no effect on exposure settings. That's because the same aperture setting on all lenses puts the same amount of light on the film (or digital sensor).
Aperture settings are a ratio of the effective opening in the lens vs the focal length. Thus, the actual opening at f/8 will be quite different for a 24mm lens vs a 200m lens. The net result, though, is the same amount of light illuminating the film/sensor in both cases.
Skip Douglas
Rawling
Mar 16, 2007 06:43 |  #3
Ah, there we go. Nice simple explanation I've just managed to miss...
Thanks a lot ^^
964 views & 0 likes for this thread, 2 members have posted to it.
1703 guests, 165 members online
