when i turn my 580EX flash on it vibrates for about 10 seconds and then stops. it will not let me change any of its settings, it just blinks. any suggestions?????
bigbird0305 Mostly Lurking 11 posts Joined Oct 2006 More info | Mar 16, 2007 20:09 | #1 when i turn my 580EX flash on it vibrates for about 10 seconds and then stops. it will not let me change any of its settings, it just blinks. any suggestions????? Just for fun
newfly5 Senior Member 372 posts Joined Nov 2005 Location: kansas More info | Mar 16, 2007 22:36 | #2 try fresh batterys then send to canon Ben
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Mar 16, 2007 23:12 | #3 Vibrates? That's an unusual thing for a flash unit to do, surely Gear Listhttp://www.codastudios.com.au
Lonnie Goldmember 1,606 posts Likes: 1 Joined Feb 2006 Location: Southern Louisiana More info | Mar 17, 2007 04:41 | #4 I can hear a servo motor working in my Sigma 500 dg st when I'm changing focal lengths in TTL mode. Assuming the 580ex has a servo in it also, that must be the culprit. Hopefully yours is still under warranty. My YouTube Vlog: https://www.youtube.com/c/GarageFlips
MarkNDixie Member 32 posts Joined Jan 2007 Location: Heart of Dixie More info | Mar 17, 2007 14:25 | #5 I had similar symptoms with a 580EX and your problem might be the same. The zoom head runs in a track and mine had popped out it. When powering up the flash, it would start clicking and the whole flash would vibrate because the zoom head was stuck. You can look into the end of the flash when you power it up and you should see the zoom head trying to move. EOS 40D, EF-S 10-22 f/3.5-4.5, EF 16-35 f/2.8 L, EF 24-70 f/2.8 L, EF 100 f/2.8, EF 70-200 f/2.8 L IS, EF 300 f/4.0 L IS, EF 100-400 f/4.5-5.6 L IS, EF 50 f/1.8
slappysam Goldmember 1,452 posts Joined Dec 2006 Location: Near Plymouth, MA More info | Mar 17, 2007 15:54 | #6 Mine does this, I assumed it was normal? It only occurs when I move the slider to the "off" position (from master or slave). It makes a click click click sound and a small vibration. 40D|10-20|17-50|70-200|580ex
MarkNDixie Member 32 posts Joined Jan 2007 Location: Heart of Dixie More info | Mar 17, 2007 16:35 | #7 Hi Slappy Sam, EOS 40D, EF-S 10-22 f/3.5-4.5, EF 16-35 f/2.8 L, EF 24-70 f/2.8 L, EF 100 f/2.8, EF 70-200 f/2.8 L IS, EF 300 f/4.0 L IS, EF 100-400 f/4.5-5.6 L IS, EF 50 f/1.8
slappysam Goldmember 1,452 posts Joined Dec 2006 Location: Near Plymouth, MA More info | Mar 17, 2007 17:47 | #8 Yes it appears the head does not move back and forth (I can see this). When I manually hit the zoom button it still clicks (same amount) but does not move still. 40D|10-20|17-50|70-200|580ex
MarkNDixie Member 32 posts Joined Jan 2007 Location: Heart of Dixie More info | Mar 17, 2007 18:05 | #9 You could try motivating it back in place as described in my first post, but since it is only a few weeks old, sending it to Canon might be the best choice to avoid any warranty issues. EOS 40D, EF-S 10-22 f/3.5-4.5, EF 16-35 f/2.8 L, EF 24-70 f/2.8 L, EF 100 f/2.8, EF 70-200 f/2.8 L IS, EF 300 f/4.0 L IS, EF 100-400 f/4.5-5.6 L IS, EF 50 f/1.8
slappysam Goldmember 1,452 posts Joined Dec 2006 Location: Near Plymouth, MA More info | Mar 17, 2007 21:00 | #10 Ahh, that is annoying. I was hoping I didn't have to send anything back. Oh well, now I have to figure out what I have to do to send it back. 40D|10-20|17-50|70-200|580ex
Mar 18, 2007 07:42 | #11 called canon. returning flash monday. they said that the focusing mech. was stuck...thanks anyway........ Just for fun
| Latest registered member was a spammer, and banned as such! 2394 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
