Thread started 18 Mar 2007 (Sunday) 12:46
Canon 10-22mm - Does it REQUIRE a slim filter?
efroten
Mar 18, 2007 12:46 |  #1
Looking at purchasing one of these lenses. Do they require a "slim" filter or will a normal UV filter work just fine?
thanks!
http://www.awordlessch​orus.com/blog/ (external link)
http://www.flickr.com/​photos/efroten/ (external link)
Gear List & Feedback
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Mar 18, 2007 14:06 |  #2
normal uv filter works fine. A buddy of mine has a cheap and thick Tiffen UV filter and I don't see any vignetting at 10mm.
Gallery: http://tomyi.smugmug.c​om/ (external link)
S2000
Mar 18, 2007 14:23 |  #3
I use regular thick filters on mine and it's fine @ 10mm
Shawn's Photo Journal - Updated 09.09.10 (external link)
Neo_gen3sis
Mar 23, 2007 17:10 |  #4
that is good to know. i thought that the 10-22mm requires a slim filter (which i did not like). now i have one more lens on my wishlist. thanks POTN!
wimg
Mar 23, 2007 20:07 |  #5
It only requires a polfilter in the slim version, as polfilters are thicker. And even then only at 10 - 12 mm.
Kind regards, Wim
looop
Mar 23, 2007 20:58 |  #6
With a uv a normal filter will be fine, however if you want a CP filter then you need the thin ones.
1d mk II, 5d, 1n-HS, Lensbaby 2.0, 24-70mm F2.8 L, 50mm F1.4, 100mm F2.0, 80-200mm F2.8 L 100-300mm F4 & TC's and flashes and stuff.
alexlex
Mar 24, 2007 10:20 |  #7
Normal UV filter works fine, but for cpl or gnd filter, look for slim/thin version.
Canon / 5DII / TS-E 24L / 50 1.4 / 100L / 16-35L f4 / 24-105L /
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Mar 24, 2007 10:48 |  #8
I have heard both ways, perhaps confussion between UV and Pol filters.
I use Hoya SHMC Pro1's which are thin but I use them for the coating quality anyway.
Macrophotography by LordV
poah
Mar 24, 2007 10:50 |  #9
you don't need a thin CP either. there is a bit or darkening of the corners but nothing you can't fix with ease
Free printer profiles PM me for info
Ascenta
Mar 24, 2007 12:26 |  #10
I bought a 77mm B+W UV filter for my 24-105, and I am very happy with it. It also fits on the 10-22 lens I just bought, so I will be purchasing another for it as well.
S2000
Mar 24, 2007 13:35 |  #11
poah wrote in post #2922869 (external link)
^:mrgreen: yep
august23
Sensitive + Shopoholic = chick?
Mar 24, 2007 13:36 |  #12
The slim and non slim versions are within cents of each other, I'd just get slim anyway.
RTT
Mar 24, 2007 15:16 |  #13
I use a normal CP with my 10-22 lens without any significant issues
EOS 350D + Grip
EF 50mm f/1.8 II
EF 28-105mm f/3-5.4-5 II
EF-S 10-22mm f/3.5-4.5
bit-tech (external link)
efroten
Mar 25, 2007 21:23 |  #14
Thanks, got the lens and a B+W MRC UV filter and it works great.
Mr. ­ Clean
Mar 25, 2007 22:05 |  #15
august23 wrote in post #2923460 (external link)
In the Hoya line, it's a considerable difference.
Mike
some shots @ Zenfolio (external link)
3,789 views & 0 likes for this thread, 14 members have posted to it.
1713 guests, 171 members online
