How do you meter for fill flash portraits outdoors? I currently do not have a external flash but intend to get one in the near future and I was hoping that I could get some advice so when I do get it I can just jump right in.
jtmorales Goldmember 1,212 posts Joined Apr 2005 Location: Colorado More info | Mar 20, 2007 22:15 | #1 How do you meter for fill flash portraits outdoors? I currently do not have a external flash but intend to get one in the near future and I was hoping that I could get some advice so when I do get it I can just jump right in.
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 20, 2007 23:05 | #2 Canon's E-TTL metering system makes outdoor fill fairly simple. Make sure custom function 14 is set to 0 (Evaluative flash metering), and keep your shutter speed at 1/250 or slower. I often use Tv mode at 1/250. "If you're not having fun, your pictures will reflect that." - Joe McNally
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 20, 2007 23:08 | #3 I use ETTL mostly. people will always try to stop you doing the right thing if it is unconventional
Mar 21, 2007 11:57 | #4 So when you meter for the sky using M do you set both your shutter and aperture to the sky metering?
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 21, 2007 11:59 | #5 Usually I'd point the camera right up and meter. Rememebr this is with focla lengths from 17 to 85mm. Close. After a certain distance the flash has no effect. people will always try to stop you doing the right thing if it is unconventional
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 21, 2007 13:01 | #6 jtmorales wrote in post #2907235 So when you meter for the sky using M do you set both your shutter and aperture to the sky metering? Whenever you're metering on a continuous light source (like the sun), shutter speed, aperture and ISO will always be part of the equation. Changing one of those things will always change the exposure unless you also make a compensating change with something else. "If you're not having fun, your pictures will reflect that." - Joe McNally
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 21, 2007 13:07 | #7 My usual settings with a polarizer on were 1/250th, f/4.0 and ISO 50. Flash was set to ETTL. people will always try to stop you doing the right thing if it is unconventional
BigMike Goldmember 1,023 posts Joined May 2006 Location: Edmonton More info | Mar 23, 2007 11:30 | #8 Similar question... Instructor at The Canadian Photography Learning Centre
sapearl Cream of the Crop More info | Mar 23, 2007 12:25 | #9 You're pretty much on the right track Mike - ideally you want the flash to put out about 2/3 to 1 stop less light than what ambient shows on the meter. And theoretically that's what the ETTL SHOULD do. GEAR LIST
sapearl Cream of the Crop More info | Mar 23, 2007 12:38 | #10 Mike, I believe there is a way with the Canon flashes to MANUALLY tell it how much light to put out - ie. full power, half power, quarter power, that sort of thing. This would allow you to precisely and manually (non-ETTL) add exactly the quantity of flash to a scene that you wished. GEAR LIST
BigMike Goldmember 1,023 posts Joined May 2006 Location: Edmonton More info | Mar 23, 2007 13:38 | #11 Thank you very much. Instructor at The Canadian Photography Learning Centre
sapearl Cream of the Crop More info | Mar 23, 2007 13:45 | #12 That's probably the best way to go Mike GEAR LIST
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 23, 2007 13:46 | #13 And all this changes with the body you have. Setting CF. 4 has a big impact on it too. people will always try to stop you doing the right thing if it is unconventional
sapearl Cream of the Crop More info | Mar 23, 2007 13:48 | #14 cosworth wrote in post #2918696 And all this changes with the body you have. Setting CF. 4 has a big impact on it too. You're absolutely right Jason - except I can't remember what CF.4 is on my 5D. I don't use too many of the custom functions. GEAR LIST
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 23, 2007 13:55 | #15 Focus with the * button. When the camera is in "manual focus" mode literally by depressing the * button, the camera will use ALL metering sensors. people will always try to stop you doing the right thing if it is unconventional
| Latest registered member is MWCarlsson 860 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
