I was just wondering if the S3 can take a series of bracketed shots in +-2 EV incrementals.
drocpsu Senior Member 472 posts Likes: 2 Joined Mar 2007 Location: New Hampshire More info | Mar 22, 2007 15:00 | #1 I was just wondering if the S3 can take a series of bracketed shots in +-2 EV incrementals. http://www.flickr.com/photos/drocpsu
Mar 22, 2007 15:37 | #2 I have and S2 and I can so you should beable too. Did you check your manual on page 76 Auto exposure Bracketing ( AEB Mode ) Canin 80D w BG-E14 EF-S 18 - 135 IS USM, Canon 60D gripped w EF-S 10-18 EF-S 18-135 is, EF 70 - 300 is usm, Canon XSi w EF-S 18-55mm is, EF-S 55-250mm is, EF 50mm f1.8 II, Canon 430 EX II, Induro AKB1, Yongnuo RF-602, Canso SX 60 HS, Canon S5 IS
I dont have one yet. I'm getting one tonight, actually, and was just wondering if it had the feature. http://www.flickr.com/photos/drocpsu
JustShootin' Senior Member 820 posts Joined Jan 2007 Location: South Florida More info | The S3 has three shot auto bracketing. Not sure of the exact incremental settings though. Gary
ThomasS. Member 189 posts Joined Oct 2006 Location: Canada's Capital More info | With the S3 Im nt sure if you can set the bracketing to exact numbers (I mainly use focus bracketing). With focus bracketing its just 'little - more - lots'. not '1 - 1.5 - 2' ...Thomas
You can download any manual from Canon's web site. Canin 80D w BG-E14 EF-S 18 - 135 IS USM, Canon 60D gripped w EF-S 10-18 EF-S 18-135 is, EF 70 - 300 is usm, Canon XSi w EF-S 18-55mm is, EF-S 55-250mm is, EF 50mm f1.8 II, Canon 430 EX II, Induro AKB1, Yongnuo RF-602, Canso SX 60 HS, Canon S5 IS
eccles Goldmember 2,948 posts Joined Jun 2006 Location: Bristol, UK More info | Mar 22, 2007 19:14 | #7 You can set the S3 to fire three shots with one nominal exposure then two either side at up to 2 stops over and under. The range can be set in 1/3 stop steps. You can also move this range from either side of nominal to all over or all under by using the exposure compensation setting. You can also do something similar with the autofocus.
| Latest registered member was a spammer, and banned as such! 2553 guests, 98 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
