Thread started 23 Mar 2007 (Friday) 07:06
Old style Manfrotto 055 Tripod
Taxboy
Mar 23, 2007 07:06 |  #1
I've got an old style 055 aluminium tripod which I have removed the bottom half of the central column to get it lower to the ground. However is there any way of removing the remaining part of the column - without sawing it off so I can get flat to the ground with this tripod
Many thanks
SkipD
Joined Dec 2002
Mar 23, 2007 07:49 |  #2
Taxboy wrote in post #2917092 (external link)
Many thanks
You could do what I did - buy the latest center column for the 3021/055 tripods. The newest column separates from a "full-length" column into one which is only a few inches long with the head mounting plate on it, and a leftover part.
With the column thus separated, you can get the 3021/055 (and 3001/190) family tripods right down on the ground by spreading the legs all out to a horizontal position.
Skip Douglas
airshaq20
Mar 23, 2007 08:50 |  #3
Are you talking about this?
http://www.bhphotovide​o.com:80 …EG&addedTroughT​ype=search (external link)
SkipD
Joined Dec 2002
Mar 23, 2007 12:08 |  #4
Nope. The part number for what I was referring to is the 055TSB. Here it is at B&H. (external link)
Here is a photo from the Bogen web site that may show it a little better:
HOSTED PHOTO DISPLAY FAILED: ATTACH id 157376 does not exist. ]
You unscrew the knob at the lower end, and the long portion comes away from the top (short) portion. The head stays intact - no messing around with remounting the head.
This center column, by the way, is STANDARD ISSUE with the 3021BPro sold these days (new, of course).
Skip Douglas
airshaq20
Mar 23, 2007 13:17 |  #5
But is the Bogen / Manfrotto 055LLA going to work in his application too?
SkipD wrote in post #2918229 (external link)
SkipD
Joined Dec 2002
Mar 23, 2007 19:09 |  #6
airshaq20 wrote in post #2918547 (external link)
While the 055LLA could work, using it means that you would have to remove your head from the original center column, then remove the center column from the tripod, then mount the 055LLA, then mount the head to the 055LLA. To go back to a full center column, you have to go through all the steps in reverse. Every time you want a short column, you repeat all the steps again.
To me, that is WAY too much work.
With the new style center column, there is only ONE step. That is to unscrew the extension that makes the center column a "column". You don't have to remove the head, reinstall the head, or any of that wasted effort.
Skip Douglas
Taxboy
Mar 24, 2007 09:51 as a reply to  @ SkipD's post |  #7
Thanks for your comments - I'll make some enquiries
:smile:
3,312 views & 0 likes for this thread, 3 members have posted to it.
1148 guests, 119 members online
