Is there a list of which lenses the 580ex automatically zooms with? It seems to be stuck on manual zoom when I use my 24-70L and 85mm 1.8. I have the flash setup in ETTL mode and I'm using it with the 1DMKIIN body.
bbc14f Senior Member 682 posts Joined Dec 2006 Location: Toronto/Koeln Germany/Bree Belgium More info | Mar 24, 2007 01:34 | #1 Is there a list of which lenses the 580ex automatically zooms with? It seems to be stuck on manual zoom when I use my 24-70L and 85mm 1.8. I have the flash setup in ETTL mode and I'm using it with the 1DMKIIN body. http://www.flickr.com/photos/michaelalexander2008/
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 24, 2007 01:39 | #2 All zooms. If it stops zooming you need to replace the batteries. That the first indication of weak battery. people will always try to stop you doing the right thing if it is unconventional
cdifoto Don't get pissy with me 34,091 posts Likes: 45 Joined Dec 2005 More info | Mar 24, 2007 01:48 | #3 bbc14f wrote in post #2921495 Is there a list of which lenses the 580ex automatically zooms with? It seems to be stuck on manual zoom when I use my 24-70L and 85mm 1.8. I have the flash setup in ETTL mode and I'm using it with the 1DMKIIN body. Well first it's not going to move on the 85mm f/1.8. It's a fixed focal length lens. Did you lose Digital Photo Professional (DPP)? Get it here
bbc14f THREAD STARTER Senior Member 682 posts Joined Dec 2006 Location: Toronto/Koeln Germany/Bree Belgium More info | Well there is a fresh set of batteries inside. http://www.flickr.com/photos/michaelalexander2008/
cdifoto Don't get pissy with me 34,091 posts Likes: 45 Joined Dec 2005 More info | Mar 24, 2007 02:04 | #5 bbc14f wrote in post #2921557 Well there is a fresh set of batteries inside. When the 85mm is on the camera it should still display 85mm on the flash display correct? And when the 24-70 is attatched it should display the same zoom that the lens is at. When I press the zoom button and turn the dial until the M disppears all I get is -- and no numbers indicating what the flashes zoom range is. Also that little gem Icon in the upper right hand corner never appears. I think its supposed to indicate that the lens and flash are zoom compatible. ![]() Are you bouncing? You'll only get zoom if you're pointing the flash straight ahead. Did you lose Digital Photo Professional (DPP)? Get it here
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 24, 2007 02:13 | #6 Exactly what i thought, flash has to be set to 90 degrees flat. people will always try to stop you doing the right thing if it is unconventional
bbc14f THREAD STARTER Senior Member 682 posts Joined Dec 2006 Location: Toronto/Koeln Germany/Bree Belgium More info | You guys all Rock...hard! I knew there was an obvious explination! Well back to picture taking, y'all have a nice day. http://www.flickr.com/photos/michaelalexander2008/
RudyM. Senior Member 489 posts Joined Feb 2007 More info | Mar 24, 2007 20:02 | #8 My 580EX set at normal, and 17-85 lens on 20D, the flash will zoom to 80mm on the 85mm lens setting. It will zoom to 105 [max] on the 105mm setting with my Sigma 70-200 f/2.8 lens attached--but it still works fine. Better Beamer works beyond that rather swell,. There is a bit of vignetting at 17mm but not really bothersome and it goes away at 24mm without the wide diffuser. Rudy M.---Thanks to this site, I'm learning something new all the time!
bbc14f THREAD STARTER Senior Member 682 posts Joined Dec 2006 Location: Toronto/Koeln Germany/Bree Belgium More info | Mar 24, 2007 23:32 | #9 Rudy M. wrote in post #2925034 My 580EX set at normal, and 17-85 lens on 20D, the flash will zoom to 80mm on the 85mm lens setting. It will zoom to 105 [max] on the 105mm setting with my Sigma 70-200 f/2.8 lens attached--but it still works fine. Better Beamer works beyond that rather swell,. There is a bit of vignetting at 17mm but not really bothersome and it goes away at 24mm without the wide diffuser. U really neen to take lo of learning pics with your set up to understand it!
| Latest registered member was a spammer, and banned as such! 2535 guests, 89 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
