Manfrotto Grip Action ball head:
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
http://www.manfrotto.com …3?sectionid=8&itemid=2013
Product description from their website:
"Take the versatility of a ball head, add true ergonomic control and you get the 322RC2: a photographic head that allows you to unblock, move, position and lock your camera with one hand in one position thanks to the revolutionary design of its grip handle, which incorporates the ball lock lever and can also mount the 322RS shutter release accessory. A friction control wheel lets you regulate the power of the blocking mechanism to match the weight of your camera/lens. The 322RC2 is made from magnesium for lightweight performance, and is designed to keep the weight of your kit as close as possible to the tripod's centre of gravity by way of its reduced height. This, matched with the precision construction of the 322RC2, gives the head its load capacity of 5kg (11lbs). NB. When the head is used in the vertical configuration (to match the function of the existing 222 head), its load capacity is only 2.5kg (5.5 lbs).
Complete with built-in bubble spirit level and quick release camera plate (standard 1/4 - 20" screw, with secondary safety pin). Suitable for use with 35mm or medium format cameras."
The "grip action" looks pretty cool, IMO. I'm not sure if this "grip" is really that much better than traditional head mechanisms... I'm in search of a nice tripod. Anyone have this one? They're advertising this head heavily in the photo mags right now.
