I am thinking of getting a Canon 200 f2.8L to use with my Canon 20D W/Grip and wanted to know if I have to use tripod or will be able to handhold it on the 1.6 crop camera. Thanks everyone.
BLEITH1965 Senior Member 465 posts Likes: 7 Joined Feb 2007 More info | Mar 24, 2007 09:04 | #1 I am thinking of getting a Canon 200 f2.8L to use with my Canon 20D W/Grip and wanted to know if I have to use tripod or will be able to handhold it on the 1.6 crop camera. Thanks everyone.
Mar 24, 2007 09:05 | #2 Depends on the shutter speed. Chris
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Mar 24, 2007 09:14 | #3 Of course... You'll want a shutter speed equal to or higher than the reciprocal of the focal length (less if you're really steady). For example, 1/320s or faster (200x1.6=320mm). La Vida Leica!
Jman13 Cream of the Crop 5,567 posts Likes: 164 Joined Dec 2005 Location: Columbus, OH More info | Mar 24, 2007 09:28 | #4 I handhold my 80-200 f/2.8L all the time, and it's significantly heavier than the 200 f/2.8. You shouldn't have any problems as long as you have sufficient shutter speed. Jordan Steele - http://www.jsteelephotos.com
liza Cream of the Crop 11,386 posts Likes: 1 Joined Feb 2005 Location: Mayberry More info | Mar 24, 2007 09:30 | #5 Permanent banOf course you can. I use it for field sports all the time. The key is to set your shutter speed high enough. It's really a very light lens with phenomenal image quality.
Yes, of course you can hand hold it. Once you get used to the camera and lens, and get comfortable with a good technique you'll probably even be able to handhold it at lower shutter speeds than indicated above. 5DMkIV + some Lenses
LesterWareham Moderator More info | Mar 24, 2007 10:43 | #7 As noted it depends on the shutter speed. But I have found it to be very handholdable with the f2.8 max ap and being very sharp wide open. It's lightness and compact nature help. My Photography Home Page
drjiveturkey Senior Member 542 posts Joined Mar 2007 Location: Leesburg, VA More info | Mar 24, 2007 14:29 | #8 It is very handholdable...especially compared to my 300 f/4 & 70-200 2.8 IS It all started as a hobby with a Rebel XT & KIT lens. $5K worth of equipment & $0 of income later, all I have to show for it is a harddrive full of pictures and priceless memories!! Yeah it's still worth it
jdos2 Member 158 posts Joined Dec 2006 Location: Shaker Heights, Ohio More info | Mar 24, 2007 14:41 | #9 Practice also goes a long way to getting better shots at slower shutter speeds with longer lenses. Lots of practice.
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | Mar 24, 2007 14:46 | #10 Do it long enough and your arms will get used to it, although you might end up with your left arm bigger than your right Anke
| Latest registered member is ealarcon 705 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
