FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 24 Mar 2007 (Saturday) 09:17
Wimberley Flash Bracket: effective when attached to the body?
kster
Mar 24, 2007 09:17 |  #1
Hello, I'm looking at the Wimberley F-2 Macro Bracket:
http://www.tripodhead.​com …racket-macro-brackets.cfm (external link)
My setup: Canon 5D with a RSS L-Plate; Canon 100mm lens;
Two questions:
1. How do people like this flash bracket for macro use? Can it also work for general photography?
2. If I attach the bracket to the camera body with the arca-swiss L plate, and use the lens hood, can the flash be positioned around the lens hood? Or would I need to mount the bracket to the lens (using a tripod collar and another RSS plate)?
For question #2, I don't want the hood casting a shadow from the flash.
Thanks!
1DmkIII and some lenses
kster
Mar 25, 2007 09:28 |  #2
Well, I went ahead and placed an order for the macro bracket. My plan is try use the bracket mounted on the camera's L plate.
TammieO
Mar 25, 2007 12:35 |  #3
That set up will work fine. Long story why, but I did use that set up with my 24-70. I was able to position the flash so there wasn't a shadow from the hood. There are better Wimberly modules to use for general flash photography. It was kind of hard to position the flash above the lens, but it did work.
Tammie
1DMkII
1,691 views & 0 likes for this thread
Latest registered member is josephferraro
961 guests, 324 members online
