What would happen if I lined the back and sides of my Stofen with tin foil. Has anyone tried this? I would not line the front or top of the stofen, so some light goes foward and up instead of all around....
darktiger Goldmember 1,944 posts Likes: 13 Joined Oct 2005 More info | Mar 25, 2007 19:47 | #1 What would happen if I lined the back and sides of my Stofen with tin foil. Has anyone tried this? I would not line the front or top of the stofen, so some light goes foward and up instead of all around....
WLR Member 97 posts Joined Dec 2006 Location: Northern NJ More info | Mar 25, 2007 20:13 | #2 I have used the partially raised white panel (of the 580ex) and also with a foil surface in place of the panel. There is slightly more shadow penetration although the overall amount of light varies little as borne out by a flash meter. For simplicity, I prefer the panel. Outside of a dog, a book is mans best friend.
jr_senator Goldmember 4,861 posts Joined Sep 2006 More info | Mar 26, 2007 05:55 | #3 darktiger wrote in post #2929815 What would happen if I lined the back and sides of my Stofen with tin foil. Has anyone tried this? I would not line the front or top of the stofen, so some light goes foward and up instead of all around.... Sounds interesting, I may just try it someday.
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Mar 26, 2007 09:06 | #4 Darktiger is thinking about flash efficiency. This is a good thing. "If you're not having fun, your pictures will reflect that." - Joe McNally
RTMiller Goldmember 1,241 posts Likes: 5 Joined Dec 2004 Location: Delaware, USA More info | I will be interested in seeing the results. But my first thought is that this sort of defeats the purpose and functionality of the Sto-Fen. Without foil, the Sto-Fen will send out light in all directions. This light will bounce and bathe the subject in all-around light, assuming there is something around for the light to bounce off of. If i'm understanding what you are going to do, the foil will block the 'side' and 'top' light and concentrate the light coming directly to the subject (like direct flash).
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 26, 2007 12:28 | #6 The flash on Manual, the Stoffen with and without the aluminum turkey roaster lining, and a flash meter ought to provide some definitive answers about what improvement in effciency of light output is accomplished! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
bphillips330 Senior Member 640 posts Joined Oct 2006 Location: ohio More info | Apr 08, 2007 19:39 | #7 any results?
| Latest registered member was a spammer, and banned as such! 1764 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
