Thread started 26 Mar 2007 (Monday) 06:07
How to...........remove paint from a lens?
perfect_pixel
Mar 26, 2007 06:07 |  #1
Hi,
I have an old mirror lens which I took apart a while back and left lying around in the shed with some DIY project in mind :rolleyes:. Just gone back to it and found plasti-kote black enamel paint (external link) on the mirror. It is overspray so lots of small dots rather than a film.
Just wondered if anyone has any ideas as to what may remove it? Going to have a go with white spirit tonight if no one shouts :shock:STOP:shock: in the meantime and was planning to get progressively stronger solvents if that doesn't shift it (ending up with a belt-sander on Thursday :lol:).
Thanks,
Steve
"...Most things in life are moments of pleasure and a lifetime of embarrassment; photography is a moment of embarrassment and a lifetime of pleasure..." ~Tony Benn
SkipD
Joined Dec 2002
Mar 26, 2007 06:23 |  #2
You run the severe risk of damaging the coating of the mirror. It is very probably a front-surfaced mirror, not a rear-surfaced mirror like the one in your bathroom. The only problem with the overspray on the mirror is a reduction of light being reflected. You will never see any dots on your image. However, the lens might now be an f/11 instead of an f/8 - depending on how much of the surface is coated with the paint.
Skip Douglas
perfect_pixel
Mar 26, 2007 06:29 |  #3
Thanks for the quick reply Skip. So you don't think it will show on the images? You've just given me option 2 - put it back together and test it...
Thanks,
Steve
SkipD
Joined Dec 2002
Mar 26, 2007 06:33 |  #4
You could put a 1/4-inch opaque sticker on the front of any conventional lens and you will never see it on the image. It would be too far out of focus to see in the image - much like shooting through a wire fence that's close to the camera. Same thing with the little dots on the mirror.
Skip Douglas
perfect_pixel
Mar 26, 2007 06:49 |  #5
Thanks Skip, that's good news (except that I don't get to play with power tools on Thursday :rolleyes::lol:)
Steve
Heatseeker99
Mar 26, 2007 08:04 |  #6
Give it a bikini wax and rip away.....all those specks should be gone :0
A.J.
1D mkIII \ 24-105L \70-200 2.8IS II \ 35L \ 85 1.8 \ Kenko 1.4x \ 580EXII \ 430EX + every piece of Nikon/Photogenic equipment imaginable at the studio.
grinchy
Mar 26, 2007 14:28 |  #7
I would try denatured alcohol
Body:
40D
Lenses:
Canon 50mm f/1.4
Canon 85mm f/1.8
Canon EF 24-105mm f/4
Misc:
580EX..Better Beamer..4 & 8gb Ridata 150X CF..Opteka Battery Grips..Kenko 1.4 TC..UV Filters..Lowepro Slingshot..Tripod
greg20d
Typo King
Mar 26, 2007 15:45 |  #8
sand blast it ...jk
40D,10d,G10,70-200Lf4is,17-55is
Tixeon
Joined Oct 2004
Mar 26, 2007 16:31 |  #9
Lacquer Thinner works well for this type of problem. Just use a very soft cloth & saturate it well, being careful to keep the Lacquer Thinner confined to the mirror surface. Don't let the thinner get on any plastic surfaces. Good Luck......
Tim
______
Any cat owner will tell you -- no one really owns a cat...
perfect_pixel
Mar 26, 2007 16:47 |  #10
Grinchy and Chigger thanks for the suggestions, I probably won't have time to try anything now until the weekend (away for work). I think I will put it back together and check for any spots/acceptable brightness as per SkipD's advice. If either turns out to be a problem then denatured alcohol and/or lacquer thinner it is!
Heatseeker99 and greg20d your sensitivity in my time of trauma is appreciated (;) :lol:)
Thanks everyone!
Steve
4,801 views & 0 likes for this thread, 6 members have posted to it.
1036 guests, 172 members online
