FORUMS Post Processing, Marketing & Presenting Photos Presentation & Building Galleries
Thread started 27 Mar 2007 (Tuesday) 03:14
html to set picture centered
azpix
Mar 27, 2007 03:14 |  #1
I have 1 picture link on my main page and it sits center horizontally. How can I also get it to sit centered vertically?
anyone know the html to make it sit at the center rather than the top of the screen.
thanks
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
CrazyPuma
Joined Jun 2005
Mar 27, 2007 22:16 |  #2
If I understand what you're wanting correctly, there is no simple html command to achieve that.
You can fudge your way around things by either using a lot of BR commands to lower the picture so it doesn't sit directly at the top of a page (for example), or put the image in a table and define where the table will sit (tho I think you'd need CSS coding rather than HTML table coding for better placement control), or use empty, unbordered, size-defined tables to "push" the image or image-in-a-table boxes down from the top, instead of BR's. Or use the invisible.gif/spacer.g​if type of trick. They all achieve the same purpose in the end, just some with more refinement.
And none of this will guarantee that people using different monitor resolutions will see the image as being in the "smack dab center" of their screen - but it will make it so the image isn't flush against the top.
Canon EOS 20D / EF100mm F2.8 USM Macro / +the kit lens that I now feel like throwing away.
Technically challenged, cheap, and lazy ...http://photos.crimsonk​eep.com/ (external link)
Double ­ Negative
*sniffles*
Mar 28, 2007 00:35 |  #3
There are a few ways to do this - CSS, DHTML and Javascript would be my guesses, offhand.
Plain HTML offers no such tag. Just <CENTER> </CENTER>
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
rlrouse
Joined Jan 2005
Mar 28, 2007 08:21 as a reply to  @ Double Negative's post |  #4
Try creating a table with one cell and set the vertical alignment of the cell to middle (VALIGN).
www.TodaysPhoto.org (external link)
jrotello
Joined Nov 2005
Mar 28, 2007 08:36 as a reply to  @ rlrouse's post |  #5
This should do it for you.
<table width="100%" height="100%">
<tr>
<td align="center" valign="middle">
<a href="url_goes_here"><img src="path_to_image_her​e" border="0"></a>
</td>
</tr>
</table>
-Jason
CrazyPuma
Joined Jun 2005
Mar 28, 2007 14:36 |  #6
Using the html height attribute to set the height of a table is generally not recommended, as it isn't considered valid code. Which isn't to say that it cannot work - particularly if you don't put that "doc type" line at the top of your scripted pages - but it may be inconsistent. And of course, if you ever decide to put content in that table other than that single image, and thus the content becomes "taller" than a users browser window, it can all go phooley.
Here, maybe this might be helpful, both about 100% height and CSS ways to define height instead.
http://apptools.com/ex​amples/tableheight.php (external link)
1,353 views & 0 likes for this thread, 5 members have posted to it.
1013 guests, 112 members online
