Lightstream wrote in post #2954424
Let's forget about the whole 'buy a cheap strobe' idea first and think about re-using what I already have, which is an ST-E2 and 430EX.
I'm wondering what is the best way to slave the Canon flash system (I am aware I will lose E-TTL and need manual power control, but that is OK) to a point and shoot camera. Some have reported excellent results synchronizing even studio monolights to a small compact camera with an optical slave and using the compact's onboard flash to fire the optical slave.
So it led me to think - can I tie an optical slave to the ST-E2, which will in turn fire all my Speedlites?
I know this is a bit of a crazy idea, but almost no 'bridge cameras' (10-12X superzoom P&S) have hot shoes or PC sync connectors to sync with flashes.
If you can get the ST-E2 to fire, then, yes, it will be able to trigger the Speedlites in Slave mode. Now, if you were to use a PW to trigger the ST-E2, I know for certain that what you want to do will work. But if you want to use an optical slave instead, that's a different matter. The problem that I've seen with the Speedlites, and this may apply to the ST-E2 as well, is that they don't work very well with optical triggering devices. They might fire once but not again unless the Speedlite is turned off and then on again.
If you can find an optical trigger that can reliably trigger the ST-E2 each and every time, then you're good to go. Cosworth as indicated in several threads that he's had success using a Sonia optical slave trigger to fire his Speedlite so that might be one avenue to look into. I personally have no experience with a Sonia triggering device so I can't say one way or the other whether it really works or not but I'm taking Cosworth's word for it.
