Two part question...
After I started looking into more pack / head flash system. I found the notes on Flash Duration being an important factor. If is typical that you PAY more moeny for a system that has a shoter flash duration? I Found two systems that output the same power (1200 watt seconds) and the only difference I can see if the one that has faster flash duration cost more money. (Ive been looking at profoto and Hensel, and Elinchrom lighting systems and Ive noticed two of the same (power) on a lot of packs.
If this typical to see shorter the duration the more expencive the pack?
Next Question is why get an Asymmetrical over a Symmetrical pack?
Which one is typically more expencive? I assume Asymmetrical since it allows for different powers to be set for each light?
