Thread started 31 Mar 2007 (Saturday) 06:28
I NEED YOUR HELP WITH SCHOOL
wagonwheel
Mar 31, 2007 06:28 |  #1
I am a mechanical engineering student. My current assignment is “owning my own business.” I am to come up with a new product or redesign an existing product and discuss how to produce and market it as if it were my business.
My question to you is: what type of new or improved upon photography related product would you like to see on the market? Thanks in advance for your help.
Lovin' my 80D
Take a look:https://dwjimages.smug​mug.com/ (external link)
SuzyView
Mar 31, 2007 06:39 |  #2
School, still have nightmares I'm taking a final exam in a class I never attended, that I need for graduation. :(
I can't think of anything that is new because WIFI makes photography for newspapers and other news services a happening already. Maybe something in the line of taking the picture, having the data go to your laptop, but you can control the editing from your camera? And then print it up somewhere else for the customer?
Zilly
Mar 31, 2007 07:02 |  #3
with u doing mechanical engineering what i would like to see is a pole extension so that you can raise the camera up above a crowd and then fire the trigger or if you want something a bit harder the same product but the ability to control the angle of the camera from the base of the extension . do you get what im going on about ?????
Dom
Follow my adventures on twitter (external link)
Car Photography (external link)
-Pleiades-
Mar 31, 2007 08:36 |  #4
Zilly ---> https://photography-on-the.net …?p=2889630&post​count=2961
~Kinnon~
Zilly
Mar 31, 2007 08:43 |  #5
thats the sort of thing just not soo big was thinking maybe two 1m long sections just a thought
Dom
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 31, 2007 08:46 |  #6
I have a couple ideas. How about a break-away flash foot?
The weak link in external flash-on-camera is the foot, which is at the end of a long leverage arm. Add something like the Wein safe Sync (external link) to reduce strobe trigger voltage & it's even worse. See the pic at the bottom.
So, design something that requires less force than what it takes to break the flash foot, & also keeps the flash from falling to the floor. It should be easy to reassemble without tools, too. Like in about 5 seconds? ;)
Notice that you should try to maintain the electrical connection component, too.
It would also extend the flash higher, to cut down on red-eye.
I have an even harder one, if you need it. :D
Wilt
Mar 31, 2007 08:59 |  #7
It is a mix of mechanical and electrical engineering, but mostly mechanical if you base it upon technology that some companies already have...
For the many 35mm film SLRs which have removeable back, design a replacement back which incorporates the digital sensor and support electronics for the sensor, to permit conversion of 35mm film camera to digital.
SkipD
Joined Dec 2002
Mar 31, 2007 09:14 |  #8
How about designing the mythical tripod - inexpensive, super-light, super-small (when collapsed), yet strong-enough and rigid-enough tripod for use with 200mm and 300mm L lenses coupled to a 2-1/2 pound camera body in a moderate breeze?
You would have no trouble marketing something that fills this niche. It seems that every day somebody gets on the forums asking for one.
Skip Douglas
PhotosGuy
Joined Feb 2004
Mar 31, 2007 09:55 |  #9
These guys tried that years ago for 35mm, & failed (Bad link) Xhttp://www.siliconfilm​.comX/ (external link) They tried to put the electronics in a cannister sized enclosure & have the sensor where the film would normally be exposed.
Then it hit the "News" again in 2002: http://www.imaging-resource.com/NEWS/1032​460933.html (external link)
Why DPReview doesn't like the idea: http://www.dpreview.co​m …12/00121501efil​magain.asp (external link)
liza
Mar 31, 2007 09:56 |  #10
I would like to see Canon come up with an 80-400 f/2.8L lens that can be hand held. With the current technology, I'd have to have a wheelbarrow to carry it. :)
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
bieber
Mar 31, 2007 10:09 |  #11
I'd like to see a new 1D with a built-in phone. The quick-command dial can be used as a rotary dial, and you can hold the whole thing to your ear by the lens and talk into the microphone that's already there!
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
Wilt
Mar 31, 2007 10:24 |  #12
PhotosGuy wrote in post #2960520 (external link)
Why DPReview didn't like the idea...
  • The sensor is considerably smaller than a 35mm frame, that means that (a) you have a focal length multiplier and (b) you'll have to use a masked focus screen to be able to properly frame a shot.
  • Technology has now overtaken the eFilm, there are lots of excellent digital cameras on the market, digital SLR's designed from the ground up to do the job are becoming more common place and prices will continue to drop next year. Remember, the eFilm is only 1.3 megapixel.
  • Storage (maximum 24 frames) and battery capacity, once you fill the eFilm you have to offload the images before you can continue, no removable storage here and once the battery power is used you'll have to recharge it.
  • Dust, nobody has yet explained how the ultra-sensitive CCD sensor surface is protected from dust / grime / damage, every time the eFilm is removed from the camera it will be exposed to the elements.
  • LCD, there's no LCD, so you loose one of the most empowering features of digital photography, instant gratification.
All of these objections can be solved merely by not trying to fit it all inside a film can-sized envelope! Most people have no issue with hanging a battery grip on an XT or 30D or 5D or putting up with the size of the 1Ds...you can fit all of the necessary things with an extension below the body for a removeable back 35mm film SLR, like this...
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/digiback.jpg
PhotosGuy
Joined Feb 2004
Mar 31, 2007 10:35 |  #13
Too bad you weren't their engineer! :D
Wilt
Mar 31, 2007 11:06 |  #14
PhotosGuy wrote in post #2960658 (external link)
The relatively young guys in their group probably simply did not realize that 35mm cameras with removeable backs ever existed! They just needed to have an old f*rt around to consult with. They thought only 'inside the box' (actually, 'inside the film canister'). That is why I am offering the idea for this student to develop!
PhotosGuy
Joined Feb 2004
Mar 31, 2007 19:56 |  #15
...probably simply did not realize that 35mm cameras with removeable backs ever existed!
My Nikon F being one of them.
2,671 views & 0 likes for this thread, 11 members have posted to it.
947 guests, 109 members online
