Thread started 31 Mar 2007 (Saturday) 17:46
whats the diffrence between 430 and 420
Zilly
Mar 31, 2007 17:46 |  #1
Hey guys
ive had a look round and carnt find a clear cut answer whats the diffrence between the 430 ex and the 420ex speedlights ?
thanks
Dom
Follow my adventures on twitter (external link)
Car Photography (external link)
crispypie
Mar 31, 2007 17:49 |  #2
Hi Dom,
I havent either of these but I believe the main difference is that the 420 does not have the manual controls found on the more recent 430
Chris.
7D mk2, 70-200F4L:-D. Tamron 28-75 :D. Grip :cool:. 50mm 1.8, :). Sigma 500 DG Super :confused:, Kenko tubes :confused:.
www.walkerphoto.co.uk (external link)
Zilly
Mar 31, 2007 18:22 |  #3
great wanna use em as a slave anyway so they should be fine
thanks
Dom
Curtis ­ N
Master Flasher
Mar 31, 2007 18:44 |  #4
Look here  (external link)for a table of features & specs of both units.
AndyCollins
Apr 03, 2007 05:32 as a reply to  @ Curtis N's post |  #5
As a newbie! and not knowing what most of the stuff in that table means would a 420ex be suitable for a canon 350d. I am new to slr cameras so never used a flash like these before.
I have heard they makes a difference over the built in flash. I will never be taking studio shots.
Are there alternatives to using canon which are cheaper? (in the UK)
thanks
Andy
ANDY
Canon 350D|Canon 18-55mm USM|Canon 70-300 IS USM(on the way!)|Jessops Extension tubes|Gorrilapod|
Curtis ­ N
Master Flasher
Apr 03, 2007 10:01 |  #6
AndyCollins wrote in post #2976635 (external link)
Yes, any "EX" series Canon Speedlite is compatible with the E-TTL II flash metering system of the 350D. To learn more about the terminology, The EOS Flash Bible (external link)is a great resource.
Yep! This threaddescribes some of the advantages.
After learning about the various features, this threadmight be a starting point. There are always cheap alternatives, but you generally get what you pay for. You need to determine what features are worth the money for your intended use.
Double ­ Negative
*sniffles*
Apr 03, 2007 14:37 |  #7
"10."
Sorry. :D
Perhaps this will help: http://www.dpreview.co​m …08/05082206cano​n430ex.asp (external link)
In a nutshell, "The Speedlite 430EX improves on many specifications of its predecessor, and includes new features to maximise digital image quality when using a flash. These include automatic selection of camera white balance settings, and auto-adjustment of the zoom flash position to match the sensor size of the camera to which the unit is attached. The Speedlite 430EX has increased its guide number to 43 (m/ISO 100 at 105mm), and has approximately 40% faster recycling time than the Speedlite 420EX."
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
b1gdaddy
Apr 03, 2007 18:44 |  #8
Double Negative wrote in post #2978995 (external link)
"10."
Sorry. :D
:lol: You only wrote what most of us were thinking ;)
Double ­ Negative
*sniffles*
Apr 04, 2007 07:29 |  #9
b1gdaddy wrote in post #2980260 (external link)
I can be like that... :D
2,286 views & 0 likes for this thread, 6 members have posted to it.
2370 guests, 102 members online
