Thread started 31 Mar 2007 (Saturday) 18:13
Should I connect my strobe flash direct to the camera?
sonshine_rae
Mar 31, 2007 18:13 |  #1
And is that even possible with my 300d rebel?
I couldn't find a pc/sync cord port on my 300d, so I've just been using my strobes as slaves. Am I blind and there is one? Or do I need to buy an adapter and attach one? The strobes came with sync cords.
At this point I've got two 110watt strobes set as slaves and am using a 420ex on camera?
Thanks in advance :),
~Rae~
~Rae~
*Hoping to recapture the joy of photography, whilst living in chaos ..* Gear List: Canon 5dm3, Canon 5d Classic, Canon 40d, Canon 20d, Canon Rebel XSI, Tamron 28-75 f/2.8 lens; Tamron 70-300 f/4-5.6 di vc USD, Canon 24-105mm F4 lens, Canon 50mm 1.8 STM lens, Canon 85 1.8 lens; Sigma 100-300mm f/4.5-6.7 DL lens, Sigma EF-500 DG Super Flash, Panasonic DMC FZ200 Optical Zoom 35mm equiv. 24-600mm.
Wilt
Mar 31, 2007 18:41 |  #2
You have to buy an adapter to sit in your hotshoe and provide a PC socket that your synch cord can be attached.
Depending upon which flash unit you are trying to trigger, there is an outside chance their trigger voltage is too high (>250v), so a Wein Safe Synch might be needed rather than an ordinary hotshoe-PC adapter. What flash are you using?
Curtis ­ N
Master Flasher
Mar 31, 2007 18:49 |  #3
You'll need a hotshoe adapter like this. (external link)
The 420EX emits a pre-flash that will trigger the strobes prematurely if you try to use it as a master.
sonshine_rae
Mar 31, 2007 18:58 |  #4
Well I can't afford AB's ... so I got a smaller Set that is adjustable.. but just a small name brand. A friend here on the boards recommended this set.
http://cgi.ebay.com …eName=STRK:MEWN​:IT&ih=012 (external link)
Oh drat figures the 420 is a poor master flash.. just one more reason why I am getting such terribly underexposed shots! Okay maybe I should use my 420ex as a slave, would it work as a hair light or anything?
sigh.. I just 'thought' I knew something about photography.. haha till I got my studio lights.. now I almost feel like I'm starting over!
~Rae~
zacker
Joined Jan 2005
Mar 31, 2007 19:08 |  #5
you can also buy the cheap ebay radio triggers... use em on all three lights! this way you CAN shoot the 420 as a BG/hair light, only thing is, the 420 has no manual settings... something to keep in mind!
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
StealthLude
Mar 31, 2007 19:20 |  #6
zacker wrote in post #2962681 (external link)
You cant use the 420ex flash as a slave to her strobes... There is no manual mode so its really not possible, or really worth her time.
The e-bay radio slaves he is talking about using is this...
http://cgi.ebay.com …tem?hash=item18​0062663980 (external link)
I did a full review on the item here:
https://photography-on-the.net/forum/showthre​ad.php?t=250975
Its actually what I use with my Strobes and my L-358 light meter. I have two sets of them. One sender unit on the camera, the other on the light meter. So I can both take photos and meter my lights w/o switches stuff around and any cables. I really recommend the ebay-slaves for a budget buyer.
If you are also intrested in these items, they are also for sale along with my L-358. Its all part of my big upgrade to the L-758 and Pocket Wizard units.
[[Gear List]]
Skype: Stealthlude
Curtis ­ N
Master Flasher
Mar 31, 2007 19:22 |  #7
The 420EX won't easily mix with studio strobes. It's an E-TTL only flash, so it only works when it's on the hotshoe, or triggered by an E-TTL master (550EX, 580EX, ST-E2).
Get the adapter for starters. The cheap E-Bay triggers can be nice, but they're unreliable enough that you'll want a plan B.
StealthLude
Mar 31, 2007 19:23 |  #8
sonshine_rae wrote in post #2962634 (external link)
ABs are good strobes but if you are just learning and want to take some simply shots what you bought is great to learn with, and you can always add more lights as you go along.
About using the 420ex as your master to trigger the strobes, it wont work, as said above, the pre-flash will trip your strobes so you will get under exposed shots. Since there is no manual, you really cant turn off the pre-flash either. Only real options are the hot-shoe adapter (wired) or e-bay slaves (wireless).
You can use pocket wizards (wirelesS), but I dont think you are prepared to spend $188 for each unit...
[[Gear List]]
Skype: Stealthlude
StealthLude
Mar 31, 2007 19:27 |  #9
Curtis N wrote in post #2962746 (external link)
Agree 100%
Depends on where and what you use them on. I hear performance of the e-bay slaves outside are not that great.. But in the studio I get very good results. I dont have many complaints except that I dont get a full 1/250 sync speed, I shoot at 1/200 or 1/160 to be safe...
When you look at the cost, you really cant complain. $25-30 for a set vs $376 for Pocket Wizards. Keep a sync cord around just incase, I guess thats the "Plan B".
[[Gear List]]
Skype: Stealthlude
sonshine_rae
Mar 31, 2007 20:33 |  #10
Wow.. I'm learning a lot today just from chatting with you all. I had no idea there was so much 'missing' in my studio setup... maybe it really wasn't my 'fault' that the images are turning out underexposed.. but rather my 'lack' of proper equipment after all!
I bet this is why 90+ % of my images were underexposed... wonder if the reason a few of mine appeared over-exposed (aka the strobes actually worked!) was because I was rapid-firing my shutter a few times trying to catch the kids smiles.. hence I 'might' have caught the mis-timed strobe firing? Confusing but interesting.
Quick question.. just to 'test' things if I use the on-camera flash (built-in) will it properly time the strobes? I'd like to at least play around learning white balance.. while I wait to get/receive my new equipment. :)
Oh and about the 420ex... hum I knew I was getting a lower end model and liked the fact that it could work with both my film an digital (which of course I practically never use film anymore).. I do remember it not having as many options as those just a little more pricey then it did though. I guess I'll either end up selling it and upgrading.. or buying an additional flash at some point.
~Rae~
Curtis ­ N
Master Flasher
Mar 31, 2007 23:47 |  #11
sonshine_rae wrote in post #2963061 (external link)
That's part of it. The pre-flash is what the camera uses for metering the flash output. Since the strobes fired with the pre-flash, this messed up the camera's metering calculations so the "real" flash from the 420EX was extremely weak. The built-in flash will give you the same problem, but there is a clunky work-around. Hit the FEL (*) button to fire the preflash, wait for the strobes to recycle, then take your shot.
zacker
Joined Jan 2005
Apr 01, 2007 06:14 |  #12
StealthLude wrote in post #2962733 (external link)
yeah i know this, i even stated it has no manual settings.... see the last line in my post ...;)
zacker
Joined Jan 2005
Apr 01, 2007 06:21 |  #13
stealthlude if you google it or better yet look at some of the posts on the strobists page on Flicker.. there are a number of Mods for the ebay slaves, tons of info and tips on getting the most from them and such....it seems the biggest problem with them is the antenna length.
FlashZebra
This space available
Apr 01, 2007 16:15 |  #14
zacker wrote in post #2964972 (external link)
I use ebay radio slaves, I have threes set and I really like their utility. But getting this utility is not without bumps in the road for many.
They are not without very significant issues, and these issues are not congealed into just one issue, the length of the antenna.
I have personally ordered over 35 sets of these devices (for my camera club members) and the biggest issue is that they just do not work at all as received. About 20% of the units I received were non functional as received. Some had non functional transmitters other had non functional receivers.
The dealer happily replaced them, but the replacement units also were about 20% defective.
So, this leads me to believe that about 20% of these units are defective "as received".
If you get a good one "as received" then they seem to work pretty well. But, my sampling indicates that about 2 out of 10 will be out of luck.
But, because of the high possibility of problems (20% is an enormous defective rate) I avoid suggesting them to anyone that is new and already confused about off camera flash. They do not need another layer of problems added to their admitted initial confusion.
Get them going with a cord, and a stable working setup. Them let them meander on their own to a inexpensive ebay radio slaves when issues surround the radio slaves will be the only issue (not general confusion about the whole process).
The OP in this post needed exactly what Wilt suggested in the first post, a simple camera hotshoe to PC adapter. And Curtis so kindly illuminated this suggestion.
The solution need not be any more complicated.
Enjoy! Lon
Titus213
Apr 01, 2007 17:23 |  #15
If you are using the 300D do make sure you check the trigger voltage on your strobes as suggested. The fact that they are inexpensive and lower powered does not mean the trigger voltage is safe. You could still fry your camera.
And once you get the connection to your camera the 'lights will come on' and your studio exposure will surely be better. I would definitely shoot with the cable before introducing radio slaves.
Dave
Perspiring photographer.
4,466 views & 0 likes for this thread, 8 members have posted to it.
2374 guests, 102 members online
