One issue that I can't seem to figure out is how to properly expose shots on bulb setting...or longer than 30 seconds. Is there some sort of formula to use...will a light meter calculate that for me?
velvetjones Member 153 posts Joined Apr 2004 Location: Great American Desert More info | Apr 13, 2004 16:13 | #1 One issue that I can't seem to figure out is how to properly expose shots on bulb setting...or longer than 30 seconds. Is there some sort of formula to use...will a light meter calculate that for me?
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 13, 2004 16:59 | #2 Easiest way is to set the camera on manual and the aperture wide open, and see what the meter says. If necessary punch the ISO up too, until you get an exposure under 30 seconds. Then start adjusting back to the aperture and ISO you really want, doubling the time for every full stop. You can take my 100-400 L away when you pry it from my cold, dead fingers.
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Apr 13, 2004 18:05 | #3 Nicely done! Good explanation! One World, One Voice Against Terror,
Apr 13, 2004 18:45 | #4 Thanks for the great explanation...It seems pretty clear. However, I don't get what you mean by histogram...I don't have a digital if that has anything to do with it.
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 13, 2004 20:02 | #5 velvetjones wrote: Thanks for the great explanation...It seems pretty clear. However, I don't get what you mean by histogram...I don't have a digital if that has anything to do with it. Ow! I feel ashamed for making the assumption. A histogram exists on many/most digital cameras, and it shows a graph of the exposure ranging from light to dark. As far as the light meter goes, my friend has one and told me that it cannot meter for exposures longer than about a second...whatever that means. Are you saying that I could just buy a light meter and (taking a cityscape shot at night) simply hold it up to get a reading if I need a 2 or 3 min. shutter speed? I am thinking about getting one anyway, and I just wanted to confirm that it is in fact capable of doing that... If the light meter maxes at 1 second then calculating a 3-minute exposure would be very difficult, if not impossible. But not all light meters max at 1 second. The Sekonic L-558
ISO 3 to ISO 8000 (1/3 steps) Shutter speeds: Ambient: 30 minutes to 1/8000 second (full, 1/2 or 1/3 steps) Plus: 1/200, 1/400 Flash: 30 minutes to 1/1000 second (full, 1/2 or 1/3 steps) Plus: 1/75, 1/80, 1/90 1/100, 1/200, and 1/400 (Granted, that's a pretty darn fancy $640 light meter that does 1-degree spot and incident metering.) But that means that this particular meter can do what you want with no issues. And you *do* have a meter in your camera. Because of reciprocity failure it's going to take some experimentation anyway, so experiment a bit and see if it works before spending a few hundred bucks on a meter. //Edit: Thinking about the various dark shadows and bright lights in a night cityscape, you're probably going to want a fairly tight spot meter to ensure that you don't blow out streetlights and lit windows. A 1- or 2-degree spot meter won't be cheap. You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 13, 2004 20:05 | #6 scottbergerphoto wrote: Nicely done! Good explanation! Hush! Talk like that is going to ruin my reputation around here, and people might start thinking that I actually know something. You can take my 100-400 L away when you pry it from my cold, dead fingers.
IndyJeff Goldmember 1,892 posts Likes: 9 Joined Oct 2003 Location: Indianapolis, IN More info | Apr 13, 2004 21:05 | #7 Scottes I am impressed. I would know how to do something like that but I don't know if I could explain it. On shooting sports...If you see it happen then you didn't get it.
PhotosGuy Cream of the Crop, R.I.P. More info | Apr 13, 2004 23:04 | #8 Hey, Scottes! Great job! FrankC - 20D, RAW, Manual everything...
nosquare2003 Senior Member 861 posts Likes: 1 Joined Dec 2003 Location: Hong Kong, China More info | Apr 14, 2004 00:18 | #9 Scottes wrote: Easiest way is to set the camera on manual and the aperture wide open, and see what the meter says. If necessary punch the ISO up too, until you get an exposure under 30 seconds. Then start adjusting back to the aperture and ISO you really want, doubling the time for every full stop. So let's say you have to set the aperture to f/4 and ISO 400 to get a reading under 30 seconds - for simplicity we'll say that the camera picks exactly 30 seconds. But you really want f/11 for good depth of field and of course you want ISO 100. f/4 to f/11 is 3 stops - to f/5.6, f/8, f/11. So you have to double 30 seconds 3 times - to 1 minute, 2 minutes, 4 minutes. ISO 400 to 100 is 2 stops - to 200, 100. So we double 2 more times - to 8 minutes, 16 minutes. So for for our example you'd set the camera for f/11, ISO 100 and an exposure of 16 minutes. Since 16 minutes is a long time to wait I'd cut that in half - thus underexposing 1 full stop - and do a picture at 8 minutes and check the histogram. Judging the histogram will give you an idea for the next try. Sure, the 8-minute shot might be an extra, unnecessary step, but why wait 16 minutes to find out it's messed up? ![]() Sure, a light meter would do this, too, but this way is quite a bit cheaper. Scottes, you are starting a good reputation of knowing a lot. 8)
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 14, 2004 00:44 | #10 nosquare2003 wrote: Scottes, you are starting a good reputation of knowing a lot. 8) Nooooooooooooooo! But if you want to judge the exposure only, could it be done by f/4, ISO400 for 30 seconds? Yep. It's the same exposure. Ignoring reciprocity failure - which is a huge thing to ignore for film at such long shutter times - f/4 ISO 400 for 30 sec would produce the exact same exposure as f/11, ISO 100 for 16 minutes. You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 14, 2004 00:51 | #11 IndyJeff wrote: Do you know of the F16 rule? Yep. Problem is that I am absolutely useless at judging light, so this is useless to me unless I'm out on a sunny cloudless day between 10 and 4. You can take my 100-400 L away when you pry it from my cold, dead fingers.
RichardtheSane Goldmember 3,011 posts Likes: 3 Joined Jun 2003 Location: Nottingham UK More info | Apr 14, 2004 10:56 | #12 Another thing to remember, on film, when doing exposures of more than a minute or so you have to take reciprocity faliure into account. If in doubt, I shut up...
Apr 14, 2004 16:44 | #13 Thanks for the great info...I really appreciate it. I am excited to try some of these out....
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Apr 14, 2004 16:47 | #14 Be sure to let us know how it worked out, and share if at all possible. You can take my 100-400 L away when you pry it from my cold, dead fingers.
| Latest registered member is AlainPre 1769 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
