kbreit wrote in post #2971649
It seems as though E-TTL falls apart pretty quickly when you're not pointing directly at the subject. Is that true?
Well, E-TTL ain't perfect, and plenty of people (including me) have complained about it. But I don't think it's any worse when bouncing flash or using modifiers. It just needs a little tweaking.
Remember - What E-TTL (in Evaluative mode) tries to do is identify the subject. This isn't so hard outdoors, or with direct flash indoors. But when you bounce the light, it will brighten up the background more. Now this is pure conjecture on my part, but I think the E-TTL system has a more difficult time identifying the subject when it's getting light reflected from the background, too. The result is inconsistent exposure.
If you switch custom function 14 to 1 (Average) it takes its reading from an eliptical area in the center of the frame (basically where the AF points are), and averages the readings within that area. The result is more consistent exposure, provided that's where your subject is.
