I've been having difficulties with my S3-IS when taking outdoor landscape photos. Typically, if the center of the frame is below the horizon, the land looks good but the sky is completely overexposed. Sometimes a blue sky will actually look white, and it's especially bad on hazy days. If the center of the frame is above the horizon, the sky will look normal but the land will be unusually dark and underexposed. Generally, I take these kinds of pictures in the landscape mode. I've had some luck lowering the brightness/exposure setting to somewhere less than 0 but greater than -1; sometimes this solves the problem, but other times, the whole picture turns out too dark. Is there a more effective way to deal with this problem?
RG
It won't work miracles if the degree of contrast is high, in that case you should try some filters
