Thread started 02 Apr 2007 (Monday) 16:35
Movie DL problem
Codium
Apr 02, 2007 16:35 |  #1
Hi,
I have a PowerShot A620. The problem is, that I can't download a movie that i've made on my trip. This is the first time this happened (i have done a lot of movies before and also successfully dled them). It was done in Standard mode (30 FPS, res. 640). It can be played on camera, but when i drag&drop it on my comp, its filesize is 0 MB and I can't play it. Also, when i try to DL it with the wizard, it says it can't be downloaded. In the detailed info it says: The I/O operation has been aborted because of either a thread exit or an application request.
What could be the problem?
Thanks a lot!
Jon
Joined Jun 2004
Apr 02, 2007 19:15 |  #2
How big is the file/how long is the movie? Your SD reader may have problems with large cards or files.
Jon
Cocker Spaniels
Codium
Apr 03, 2007 12:00 |  #3
It's 324 MB (about 3 min)
And I have another movie done in same quality, which is only 11.8 MB (8 secs) and it doesn't copy either.
BTW, i don't use a direct SD reader component, i have a USB from the camera.
Jon
Joined Jun 2004
Apr 03, 2007 12:34 |  #4
Computer and OS version? But with a card reader the transfers will be much faster and easier. I've pulled 9 min. clips from my A620's card over in no time (relatively) using a card reader.
Jon
Cocker Spaniels
Codium
Apr 03, 2007 12:46 as a reply to  @ Jon's post |  #5
XP, conf.= Celeron 1700 MHz, 768 DDR, ATI Radeon 9000 pro, motherboard QDI...
I don't think this is a problem, because i've downloaded lots of movies by now and it has always worked perfectly. Is it possible that there would be some lock engaged in the camera or something, because my father used the camera for some time and he might have messed something up in the settings, cuz he is not very familliar with technics of this kind :D ?
Jon
Joined Jun 2004
Apr 03, 2007 13:33 |  #6
Tried the card with a reader or the camera on another computer? sure the card hasn't been locked?
Jon
Cocker Spaniels
Codium
Apr 03, 2007 16:35 as a reply to  @ Jon's post |  #7
Yes, I'v tried with cnahging lock position but didn't work either. I will give he card to my classm8 to try to Dl he movies. Thx for the help.
1,873 views & 0 likes for this thread, 2 members have posted to it.
Movie DL problem
2425 guests, 104 members online
